Pure Direct vs Direct Stereo (Help!)
*Seby*-Polk-
Hi everybody !!!!
I need some help and information about the "pure direct" and "direct stereo" modes availables on the most receiver brands.
I Have a Yamaha RX-V657 and don't know the real quality difference about this modes to listen ONLY 2CH audio. What's the best ?? Why ???
Thanks for submit !!!
My current new system (step by step
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
Post edited by *Seby*-Polk- on
Try it and see if you like the difference. I use Pure Direct for 2 CH.Michael
NORTH of 60° -
i like 19th century cathedral church basement and 1974 L.A. Jazz club settings better...
both piggybacked onto DPLIIx.
rock on. -
OK. Pure direct is most clean signal than direct right ??? For music or for movies too ?My current new system (step by step
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² ) -
i beleive in pure direct the signal is more concentrated to the speakers, the receiver will turn off all un-necessary things like the digital display for instance. direct stereo will leave these things running. there is a slight difference between the two but not much really, pure direct is good for music, but i also like listening to music in dts-neo6,
for movies i would just stick to 5.1 or 6.1 ,most movies are made for it these days so why would you watch them in stereo. -
Pure Direct is for people that believe that extra devices, flourescent displays, etc have an effect on sound quality. There's no right or wrong. I would consider it a nice perk to have that option, which I do have available in a couple pieces of gear.
Direct Stereo - I have no idea.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Pure Direct kills all unnecessary processing and circuits, including video processing/switching, and front display, etc... This also bypasses any speaker settings made, as well as bass management, and sub. It will play any source in full range stereo to your mains.
Direct stereo will play any source is standard stereo. However this will leave all video circuits active as well as bass management selections. So if you have your two mains set to small your subwoofer will still operate.
Hope that made sense.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
You can adjust the "treeble" and "bass" parameters in Pure direct mode ???My current new system (step by step
*Seby*-Polk- wrote:You can adjust the "treeble" and "bass" parameters in Pure direct mode ???
Sorry left that out. In pure direct mode bass and treble adjustments are also bypassed.HT
2 CH
Anybody has experience with MONSTER cables ??? I mean, is recommended uses Monster cables, for example, to connect dvd player-receiver via digital coaxial ??? It has better sound quality??My current new system (step by step
We dont recomend Monster Cable...
Signal Cable
Zebra Cable
Blue Jeans Cable
Cobalt Cables
Kimber Kable
Nordost
IXOS
Audioquest
PS Audio
Etc etc- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
yes??? What's the reason ??My current new system (step by step
Seby,
As far as speaker wire goes, Monster Cable does not advertise their gauge. Instead they run a plastic insert through the middle of their stranded cable to make it appear as thick as equivalent size gauge. On top of this, they sell their cable at a premium price.
I have found that I could purchase better quality cable at a cheaper price at Blue Jean Cables. From a company like BJ, I know exactly what size wire I am getting, the quality I am getting, the connectors I am getting, and all for about half the price of the advertised Monster cable.
It just puts a bad taste in your mouth to have someone tell you how great they are but are not confident enough to give you any specs to compare quality. Monster is to cable as Bose is to speakers.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Better bang for the buck elsewhere.HT
2 CH
I thought that Plastic insert was a New Magical dohickey
that M Cable uses to improve signal clarity.
I've been buying 14 guage cable with nice jackets
from a local HW store for 30cpf. -
Monster Cable has very questionable business practices, which we recomend no one supports.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
OK. I don't go with Monsters (and save the bucks
) . Thanks
Other question....Is better the Coaxial Digital or Optical digital cables ??? What of those have superior quality ????My current new system (step by step
