Dont ya hate when this happens??
VR3
You countersink the hole... pre-drilled all the way through, perfect size for a screw head, perfect size for the shank... It should be done with already
You start turning the screw down into the hole, about half way down - the board SPLITS...
EFFFF.
EFFFF.
Post edited by VR3 on
Lubrication...............it works everytime.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Haha, Im just slightly dissapointed it split - I am just going to have to puddy it up, I patched it - it will have to do. I cant throw away a 10 dollar panel... lol - aint no way...
Need to buy me a big stick of wax.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Rub a little bar soap on the screw....
Will have to try that... hmmm...
I wish truck bed liner took in glue - i didnt even want to use any screws! lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Dennis Gardner wrote:Lubrication...............it works everytime.
this applies to SOOOOOOOOOO many facets of everyday life
Living Room 2 Channel -
Upstairs 2 Channel Rig -
