Any Camera Guru's Out There
janmike
I recently purchased a Canon Digital Rebel EOS 300D (used) and would like to add an external flash. I also have a Canon EOS 3000 35mm. Ideally, I would like a flash that I could use on both cameras as I do with all my lenses. A local camera shop told me to purchase the Canon 430EX Speedlite and wondered what else I could use. I would mainly be using it for shots in an arena and a school auditorium. I did see a few 420EX's for sale on ebay and wondered what else would work for me. Any help would be appreciated. Thanks Folks.
Michael
NORTH of 60°
NORTH of 60°
I've got several Eos models. I use a 420 I got in the early 90's. Any model number larger will probably be newer and would work fine. Auditoriums are tough to shoot. Tele-lenses and a good (Bogen,etc.) monopod comes in handy. You would need a flash with a pretty good throw. You can sink as much in photo as in audio. Ain't in fun.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
You got that right. The nice about this SLR is that all the lenses I had with the 35mm work with the digital. And to boot, my 300mm is now 450mm on the digital body. Do you think the 420 would throw far enough for the shots. I guessing at 50 feet or so.Michael
NORTH of 60° -
Without looking it up, I believe that the 430EX is basically the same as the 420EX with additional support for E-TTL II. I may be wrong about that..
I've got the 420EX and while it's a very good flash and might be sufficient for what you describe, I think you'd be better off with the 580EX (or the older 550EX). It's quite a bit more money, but auditoriums and arenas are tough. At those focal lengths and distances, if you don't want to have to crank the ISO way up I think you'll find you need more flash power. The 550 & 580 only give you a stop over the 420, but every little bit helps in a situation where you need it. It never hurts to have more than you need. You might also check on borrowing or renting a 420 or 430 from another photographer or camera shop and just see if it works for what you want to photograph.
If your 300D doesn't already have the firmware hack installed that gives you FEC, then I'd recommend looking into that as well.
At home I've got some shots I took at a school Christmas program, that I could show you for examples. If I get a chance to swing by there, I'll try to post one or two to show you.
Jason -
That would great Jason. Thanks. There is a feature on the 430EX (E-TTL II, I beleive) that my 300D does not support. I am still investigating this. No sense paying for a feature that I cannot use.Michael
NORTH of 60° -
I almost forgot. Let me see if I can find those pictures...
Here's a couple. They're not great pictures, but it should give you an idea of what the 420EX can do on the 300D. This was in a very dark auditorium with low-tech (note the clamp-on light in one picture) and not very bright stage lighting. I was about 50 ft away and shooting with the 300D at ISO 400. I have the hacked firmware and had FEC set at +2/3. 200mm, F5, 1/200th sec. with the 420EX. I was able to light up the stage pretty well, but it took some trial-and-error with the flash exposure compensation, due to the white costumes. I even had a few where I successfully bounced the flash off the ceiling. These have been cropped in Photoshop and had some minor corrections applied. I'm on dial-up, so I had to compress them substantially. -
True the 300D is not TTL-II but all newer Canon cameras are/will be so if you ever upgrade your camera body, it would be good to have a TTL-II flash. Grabbing the 430 today is not a waste because the 430 is compatable with all EOS SLRs and DSLRs and has a faster recharge cycle than the older 420, among other improved specs. here's a link to the specs: http://consumer.usa.canon.com/ir/controller?act=ModelTechSpecsAct&fcategoryid=141&modelid=11923Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Thanks for info. Great stuff. The 420 did a great job IMO. I agree, the 430 may be the way to go for future consideration.Michael
NORTH of 60° -
I am seeing a lot of replacment flashes for the 430EX (not Canon). Anyone tried any of these and done a comparison.Michael
NORTH of 60° -
Personally, no. But a lot of people seem to be fond of the Sigma 500 DG Super, which you might be able to pick up for about the same price as a 420EX. You could post your question on the forums at http://www.dpreview.com to get your question in front of a lot of people with experience. Or just use the search feature and see if you can find some similar questions.
Also, http://www.fredmiranda.com/ has a very active buy/sell forum. If you're looking used, that would be an excellent place to look. You have to register first.
Jason -
Well I picked up a few used toys the other day to add to the photography thing. I grabbed a Speedlite 420EX for those indoor shots and a Canon EF 50mm 1:1.8 II Autofocus Lens. I lens will be an improvement on the 28-80mm lens I currently have. Thanks for the advice folks.Michael
NORTH of 60° -
Awesome! Welcome to another addiction...photography!
I'm on the Nikon end of the spectrum, but Canon makes equally fine stuff too.
Here's my site with some stuff...
www.strongdigitalart.com
Enjoy,
JohnNo excuses! -
i had a Nikon D50 and got bitten by the bug and sold that and bought a Nikon D80 w/Nikon 70-300mm VR lense and a Sigma 17-70mm lense. Another expensive toy.Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18 -
My Mother is visiting us here in Yellowknife and I have had the time to do a little more exploring and shoot a few more pics. The new 50mm lens is real nice.Michael
NORTH of 60°
