Hooking up Cable
ch57
I have an RMDS-1 system with Panasonic DVD recorder and Cable TV, Scientific Atlantic Explorer 2100 cable box. Used to have Direct TV hooked up thru RMDS, but need info for cable box.
Where do the cable box leads go on the back of the RMDS?
Post edited by ch57 on
Use the same exact inputs you used for sat.....If the cablebox only has mono out, use a stereo VCR ,run the coax signal out of the box to the Vcr, then use the rca outs to the inputs you used for sat.Dan
