venomclan, you might need to clear out your PM box
Mazeroth
Mazeroth Posts: 1,585
edited April 2024 in Clubhouse Archives
I've sent you two PMs without a reply and am hoping it's because your PM box is full.
Does it usually tell you if the recipient's box is full?
  • Skynut
    Skynut Posts: 2,967
    edited February 2006
    Wake Up Venomclan
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
