polk dx components
Systems
Systems Posts: 14,872
edited October 2001 in Car Audio & Electronics
I know this is the momo site but I have a question. Will the polk dx 6.75 components "drop in" the openings of a 98 Saturn Sc2, and will 35 watts drive them very efficently? Thanx
Testing
Testing
Testing
  • Systems
    edited September 2001
    I'm not sure if they'll fit properly, you might want to call crutchfiled or go on their website. They should be able to answer your question. Regarding the power, when i first bought my dx component system I ran them off my deck which is 40x4 RMS. I wasn't very impressed with the performance. I then bought a Rockford 200 a4 which, bridged, supplied 100 watts to each channel and they sounded great.
    Testing
    Testing
    Testing
