HK AVR 7300 and tweeter issues
Hello, as you can see from my signature I am planning on buying those polk audio speakers. I have talked to some people who say that Harman Kardon receivers are not bright and produce soft soft, because of the same people tell me that the polk audio non metal tweeters will not produce quality sound. Is this true? Would the sound quality be better if they were a metal tweeter?
HK AVR 7300
Polk RTi10
Polk RTi4
Polk FXi4
Polk CSi3
Velodyne 10" sub
HK AVR 7300
Polk RTi10
Polk RTi4
Polk FXi4
Polk CSi3
Velodyne 10" sub
Harman Kardon AVR 7300
Monster MK II Power Center
Logitech Harmony 890
HSU VTF-3 MK2 Sub
Polk Audio RTi10
Polk Audio RTi6
Polk Audio FXi3
Polk Audio CSi5
HSU VTF-3 MK2 Sub
Polk Audio RTi10
Polk Audio RTi6
Polk Audio FXi3
Polk Audio CSi5
Post edited by Giuseppe on
solely a matter of opinion. some like metal tweets, some like me, think metal tweets were invented with the sole purposes of making me want to shove a coat hanger in my ear until it bleeds.
seriously though, some would say even the RTi's are a skosh bright, but perfect for home theater. with that Haarmon Kaardon, you should be a-ok
I would suggest you make sure the receiver has pre outs before you get it. seperate amplification down the road would benefit those RTi10's, but it is not nessecary. just thinking for the future possible upgradesLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
You should be fine...like oskigod, I dont like metal tweeters...there are some notable exceptions but I digress...7300 is a beast!System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD -
I run a HK 235 on 4 R50's in the front.
2-50's for center and 2 for mains.
I went for a higher powered Onkyo when first set up.
Onkyo was just OK.
Hooked up the Harmon, and it produces a sound so clear
that it made the Onkyo sound muffled.
You can't go wrong with a H-K. -
The speakers in my signature (Monitors) sounds fabulous with the HK receiver. What's the phrase to describe it? Warmy detailed? Very clear trebble but never harsh or too bright, but everything still has tremendous clarity.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
all sounds well for me. eats up any music i through at it. just fly your **** over to the states and come check it out.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments.
