Kenwood receiver with preouts
krabby5
I have Kenwood VR-6070 that is about 2 years old...I have just purchased a used pair of RT800i's and a SVS 25-31 PCi sub...I also have a cs 400i center and (cough) Bose surrounds..
Since so many people have ripped my receiver (not as much as the Bose, though
), I am wondering what I could be missing with a better receiver. The receiver does have preouts...should I try adding an amp or 2 to power the fronts and center? or try a good HK instead...then maybe separates later?
If the amp route, what should I try? think bang for the buck!
Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
Post edited by krabby5 on
i'd go for amps. If you like your receiver that's all that matters. It should make for a decent pre.
Amps: Try Rotel, Outlaw, Adcom, NAD -
All the receiver would do, if you add amps, is act as a pre. Once you get to a point that will make a big difference. I might not make so much of a difference now. So, I would say go with some external amplification for at least your mains, possible all the front speakers (L-C-R).
Here are some manufacturers to start looking at:
Outlaw Audio Products Page
Rotel HT Multi-Channel Amplifiers
Adcom Multi-Channel Amplifiers
B&K Products
NAD Home Theater Products
Audiosource Amplifiers
AMC Amplifiers
Sunfire Amplifiers
Parasound
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
..and replace the powercord with something rated for audiophiles if possible.Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
Conditioner: Isotek
I'm guessing if I spent $600-800 on a HK receiver to replace my Kenwood, I wouldn't notice a big difference in sound quality...
But if I took that same cash and bought amps to power the front and center speakers (thus keeping the Kenwood and using its pre-outs), I WOULD notice a difference...
am I correct ?Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub -
You are very correct.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
It doesn't always work out the way you think. Check out Mick's recent thread on adding Adcoms to a great set of LSi15s. He was dissapointed at the lack of improvement over his Pioneer receiver.
The 800s aren't as hard to drive as the LSi line. I would upgrade your surrounds, then go for amps, but thats just me.
Adcom and LSi15 upgrade whoasHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
which surrounds would match the rt800i and cs400i besides the fx300i/fx500i?
are there any newer models?Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
