X-over modification Question
jdhdiggs
jdhdiggs Posts: 4,305
edited February 2006 in DIY, Mods & Tweaks
My speakers have an external, high level X-over. I also have schematics and some decent soldering skill. How difficult would it be to modify the X-over from handling high level to line level inputs and output the same?
Should I just start over with the schematics and build from scratch? My concern is the output impedence causing a screw up in the X-over and popping parts. My EE is getting rusty so I'm looking for input from someonw whose done something like this or can use the schematic to give me an idea of mods needed.
The X-over is the external portion of the belows. I believe I have the rev 1, but I can't be sure untill I get back home.
I'm hoping this is just a case of adding RCA plugs and a resistor...
Purpose: Active bi-amping
There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
Post edited by jdhdiggs on
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited January 2006
    The inductance coils, and capacitor values are set to work with the impeadance
    of your drivers to achive their cross over freq. If you try coping this to make a line level crossover to place inbetween your pre. and your amp the frequency(s) are going to be way off due to impeance mismatch (going from 4 or 8 ohms on the speakers to 10k+ohms on the electronics. at least thats what I seem to recall from my 4 months of electronic classes.
  • jdhdiggs
    edited January 2006
    That's my concern. However, the high ohm levels would be on each side of the crossover. How that affects the circuit beyond limting current flow, well, I left Pspice in my other computer and I am not pulling out my circuits book if I can help it.
  • jdhdiggs
    Just a follow up, tried this out. High's make it through, mids and bass are barely audible.
  • ohskigod
    ohskigod Posts: 6,505
    whats speakers are you playing with, the maggies? or a diy project
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • jdhdiggs
    The maggies external X-over.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    You should call or write the speaker manufacturer. In addition the the bi-amping modification, they might also be able to provide other performance enhancement tips.
  • pjdami
    pjdami Posts: 1,894
    Did you try searching the MUG (Magnepan User's Group) forum or posting there? Check out the tweaks section.
    http://www.integracoustics.com/MUG/MUG/
