External Amps? Which ones?
tledoux
tledoux Posts: 17
edited February 2006 in Electronics
When I bi-amp'd my RTi10, I lost my internal Zone 2 amp in my Yamaha RX-V1600.
So now I need to get an external amp for the Zone 2. Does anyone have any good
suggestions for an external amp (2 channel)? It doesn't have to be the world's best as
Zone 2 is not used all that often.
Thanks in advance,
TL
Fronts: Polk RTi10
Surrounds: Polk TC615i
Center: Polk CSi5
Sub: Velodyne DLS-3750R
Receiver: Yamaha RX-V1600
Amplifier: Outlaw 7500
DVD/CD: Sony DVP-CX995V
HDTV: Sony KP-51HW40
RC: Philips TSU-6000
Post edited by tledoux on
  • ND13
    ND13 Posts: 7,601
    Audiosource makes a great entry level amp that would be more than adequate for not alot of scratch. So does Outlaw.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • audiobliss
    audiobliss Posts: 12,518
    I would personally suggest getting a separate amp to power the RTi10, instead of biamping them with the receiver, and then using the receiver's Zone 2 amp for Zone 2. The RTi10 would really benefit from some nice amplification, and sad to say that's not what a Yamaha receiver is for. What are you powering in Zone 2?
    Here's a list of amplifier manufacturers to get you started with research:
    Outlaw Audio Products Page
    Rotel HT Multi-Channel Amplifiers
    Adcom Multi-Channel Amplifiers
    B&K Products
    NAD Home Theater Products
    Audosource Amplifiers
    AMC Amplifiers
    Sunfire Amplifiers
    Parasound
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • tledoux
    tledoux Posts: 17
    In Zone 2 I just have 2 more in-wall Polk TC615i's for the gameroom. The system overall is just used as general entertainment (33% normal TV, 33% Music, 33% DVD/part-time HT, 1% off). I'm fairly new to the whole "high-end audio", but definitely noticed a difference when I bi-amped the RTi10's from the Yamaha. Thanks for your suggestion, I didn't even think about getting an external amp for the RTi10's and using the Yamaha for Zone 2. Also thanks for the links, that helps a lot.
    TL
    Fronts: Polk RTi10
    Center: Polk CSi5
  • audiobliss
    No problem. You would notice much more of an improvement powering the RTi10s with a separate amp and using Zone 2 amps to power Zone 2 than what you proposed. That's what I would personally do.
    I would just look for a more affordable 2-channel amplifier. After looking at your setup and hearing how you use your system, I wouldn't pay more than about $400 or so for the amplifier. I would keep a look out for some used Adcom amps on the FM here as they're nice amps and shouldn't run you too much. Since you aren't very demanding of your system I think I would be fairly confident in also recommending an Audiosource AMP300. It provides 150wpc into 8ohms and shouldn't run you much, either.
    Have fun researching!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • propman07
    propman07 Posts: 52
    Hey-
    I have a pair of power hungry RTi10s as well, and was also looking into an entry level amp. I have been looking at a thread on another forum that has members using a Crown XLS-402B pro amp, with some success. I was also looking at the Audiosource AMP-300 as a candidate. Any opinions?
    Here are the links to the two candidates:
    Crown XLS-402
    Audiosource AMP-300
    I've been able to find the Crown on the bay for around $250 shipped. The Audiosource can be had for around $370 shipped.
    Thanks.
    David
    HT Setup
    Display: Sony KDF-60XS955
    Receiver: Sony STR-DA5000ES
    Front Main: Polk RTi10
    Center: Polk CSi5
    Surround: Polk FXi3
    Subwoofer: SVS-PB12-ISD
  • tledoux
    tledoux Posts: 17
    OK, I've narrowed it down a bit. I'm trying to decide between the AudioSource AMP300 to drive the front LR RTi10's, or spend a bit more and get the Outlaw 7125 and use it drive all of my 5.1 HTR speakers. Of course I would need a new center channel, since the Bose VCS-10 can't handle the 125 watts from the 7125 (but I was looking for an excuse to get a Polk CSi5 anyways). Would using the Outlaw really sound that much better than the AudioSource? (Yes, I know it is all very subjective, but thats why I am asking for people's opinions).
    Thanks in advance,
    TL
    Fronts: Polk RTi10
    Center: Polk CSi5
  • pearsall001
    pearsall001 Posts: 5,293
    Check out the Behringer A500 amps. They are a steal at $180. apiece. Plenty of excellent clean power. 160X2 8ohm, 230x2 4 ohm, 500watt mono-bridged. Parts express carries them w/ a 45 day return policy. That gives you plenty of time to compare against other amps.
