Eliminating extraneous rattles in the room
JediCowboy
The only thing left for me ot do is get rid of a *very* bothersome rattle that occurs mostly because of my center speaker placement, though other speakers cause this same rattle to a lesser extent.
My center (CSi40, set to SMALL) is positioned on the shelf of the TV stand, right below the TV. I'm not going to move it above the TV, even though I would prefer that position, because it just looks awkward and partially blocks a painting I have on the wall. Moving the painting higher would just look worse.
I have a Sony 36" Wega, model #KV-36FV1. This is the kind with the television speakers on the side of the screen, not beneath like in other models.
The molded plastic framing the screen is solid across the bottom (where the Sony logo is). The problem is that this lower part of the plastic frame is loose and rattles horribly at some lower frequencies, specifically 130 - 95 Hz.
If I push on the Sony logo and hold it in the rattle stops. However I can't remove the plastic frame to put a little bit of epoxy there to hold it in place and keeping my finger on it is just silly. I'm not a little Dutch Boy!
Has anyone else come across a similar problem and how was it resolved?
The Force is with Me -- YEEHAW!!!
Denon 3802
Mains -- RTi70s Biwired
Center -- CSi40 Biwired
Surrounds -- FXi50s
Denon 3802
Surrounds -- FXi50s
Post edited by JediCowboy on
Duct tape that motherDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Asthetics?
Let me rephrase . . . How do I fix this in a way that would be presentable for company?The Force is with Me -- YEEHAW!!!
Denon 3802
Surrounds -- FXi50s -
Thumbtacks.:DTwo Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
"If you could put speakers in a needle, I'd never see him again..." - My Girlfriend -
OK Hoosier, believe it or not that silly remark inspired a fix that worked! If I couldn't hold it down, why not push it out?
The front plastic was loose enough to pull back slightly and to keep it in position I gently pushed 4 folded squares of toilet paper behind the plastic with a flathead screwdriver. It created just enough space to prevent the rattle caused by the plastic against the glass. And it doesn't bulge out unsightly either.
Its all good -- RESPECT!The Force is with Me -- YEEHAW!!!
Denon 3802
If you can take the face off, duct tape will still work. Roll a small piece over on itself so it's double sided sticky, then stick a little wad of whatever *styrofoam, rolled up ducttape, unlucky insect* on the tape on the place you believe to be the rattle point and put the face back on. A little tweaking and you should have it.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
