Superbowl XL Sound - kickin' it old school.
RuSsMaN
RuSsMaN Posts: 17,986
edited February 2006 in 2 Channel Audio
Going full on MONO this year.
Bogen DB130 Tube integrated
Electrovoice 'The Aristocrat' Corner Horn w/ TRX-12b Coax driver
Lamp cord
This one is for Granddad.
Cheers,
Russ
Post edited by RuSsMaN on
  • George Grand
    George Grand Posts: 12,258
    That "Aristocrat" is a dead ringer for the pair of E-V "Marquis" I have been using in my garage rig for about the last ten years. About the same size and all. Mine don't play the Super Bowl though. My cabinets MIGHT even be a little nicer. "Aristocrat" have RCA input or regular speaker terms? Mine have RCA inputs.
    George
  • dkg999
    dkg999 Posts: 5,647
    Nice! Very Nice!
    DKG999
  • RuSsMaN
    I've never seen a Marquis corner horn, I had some (later I guess) Marquis cabs that were regular ported boxes - still nice though. The Aristocrat was the Paul Klipsch designed corner horn, I'm pretty sure anyway.
    One brilliance control, and the standard 2-screw posts on the rear. Another pair I have are wired with 1/4inch inputs for the speaker terms.
    Cheers,
    Russ
  • polksda
    polksda Posts: 716
    Sad thing is, with the **** sound of the halftime show, stereo or surround would make absolutely no difference whatsoever... this is putrid.
    Note to promoters: do not schedule AARP convention during halftime show.
  • George Grand
    I have loved The Rolling Stones since 1964, and disliked Mick Jagger for the same duration. How the f%ck do you get to be a rock/sex legend, when all you've ever done is prance around like a chick for 40 years? Brian Jones is spinnin' in his grave.
    Sound sucked, and at this point, they are definitely in the running and maybe on top of the World's UGLIEST Rock & Roll Band category, but not the World's GREATEST Rock & Roll Band category. Hang it up girls, how much money is enough?
    George Grand (of the Jersey Grands)
  • ohskigod
    ohskigod Posts: 6,505
    looks like you can pull on Mick Jagger's face skin like friggin taffy!
    as many have said, after a nuclear halocaust, there will only be a few cocroaches, bacteria, and the rolling stones
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • George Grand
    I didn't see the corner horn part of your original post. Mine has some sort of co-axial driver inside also, but it's been a long time since I cracked them open. Like the day after I got them. Got a brilliance control on the **** end too.
  • Airplay355
    Airplay355 Posts: 4,298
    I thought it was a few roaches, twinkies and cher's face? Guess we need to add Mick jaggers face to that list.
    Nice rig russ. Is that speaker designed for mono? Or did you only find one?
  • RuSsMaN
    I've got several, but yes, they were sold back in the 'mono' days as well.
    If you have the control George, I bet they are the TRX12b's - which are one of, if not THE most desireable EV speaker. The call it a 3-way, to me it's a two way. 12" with a whizzer (thats 2 per EV), and a center mounted EV T-35 horn tweeter (the same that Klipsch used from the Heresy to the Klipschorn).
    The drivers alone can bring near $400 a pair, depending on condition. If yours are like mine, they've probably never been out of the original cabs.
    Cheers,
    Russ
  • George Grand
    They haven't been out of these cabs since they've been HERE, that's for sure. I'm sure I advertised these damn speakers just about everywhere (here too) for $100/pair local pick-up, 5 YEARS AGO. Guess what ain't happening now?
    I picked up a couple raw Magnavox horns not long ago. Should I get a boner or what?
  • RuSsMaN
    I remember those threads, I do.
    Email me a picture, or some ID numbers stamped on the mag or cone - Jensen / Magnavox drivers don't bring much, but some of the horns the Japanese go CRAZY for. Like 3 to 5 Franklins crazy.
  • George Grand
    You think they'll fly over and do a local p/u?
    Horn #1
    Mahaganovox
    580088-1
    70.43
    Horn #2
    Mahaganovox
    580088-1
    70.40
    Each one one has "Japan" stamped into the narrow part of the outer throat. I'm hoping that part gives THEM a boner.
  • RuSsMaN
    Anything on the Mag structure? Jensen Magnavox should start with a 220 or 232. I'll dig a little deeper tomorrow, my magic 8 ball (rum filled) came up with nothing.
    No, but they will pay in spades for shipping.
  • George Grand
    Nothing on either magnet structure other than a disclaimer from The Mahaganovox Company about driver unit disassembly voiding the warranty.
  • dorokusai
    dorokusai Posts: 25,576
    Is Mahaganavox the low end Magnavox? Jesse, do you know about this shite?
  • George Grand
    It figures one of the more astute among us finally gets it. I thought it would happen sooner. The same company that made his pipe.
