LSi 9 - ...
MxStYlEpOlKmAn
If i were to use Lsi 9's for mains...what would U USE that would cost under 1500 dollars as an amp, preamp, receiver, etc etc...what woul du use?
Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
I promised myself
Damn you all! - ATC
Post edited by MxStYlEpOlKmAn on
thats not my budget...my budgets like 300 dollars...i was just wondering incase i get really insane one day and decide to go shopping...lol...which i doubt will never happen...LOLDamn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
i can buy....myself a quiet vcr...lolDamn you all, damn you all to hell.......
I promised myself
For $300, if I look at the best deals I ever made, and it could take awhile to find deals like this, I would use the Luxman CD player with tube output I found for $99 with no remote found at a blowout sale and the $200 dollar 200 watt per channel Soundcraftsmen amp which an ebay seller bought a bulk load of then refurbished. It can be done if you are willing to do the looking and take your chances! BTW, the $99 Luxman is still my CD player of choice which I have used everyday for the last 5 years.
parasound amps can often be found on the cheap.
I had an 750 that I picked up for $200 which can drive 4Ohm
and knocked the socks off my 800is. -
im really interested in the lsi9's because i cant stand floorstanders...but it'd be a long time before i'd get a pair...probally will get the other models of the high end polk speaks that come out...lol..Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC
