psw 10 bridging
ecohee
Do you mean run two of them together? If so, yes, simply use a Y adaptor (or two) if you have it hooked up using the line level connections. If using the speaker level connections, you can simply daisy chain the speaker level outputs from one to the speaker level inputs of the other.-Eric
-Polk Audio -
if thats not what you mean, a sub is only one channel. if you hook 2 channels up to it, either by speaker inputs or the 2 channel line level inputs, it will convert it to a mono signal anyway, so there is nothing to bridge amp wise, it is allready one channel.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
neverminddvd player: samsung DVD-HD850
receiver: Denon avr5700
center: polk cs400
fronts: polk rt800i
surrounds: Unknown Polk monitor? series.
sub: svs pb12 isd/v
tv: 46 inch samsung -
Would it be better to bridge 2 psw10s or to go up to a 12 inch sub?
