lsi and rti again...
Here's my question.yesterday,I went and listened to some polks at sound advice.The rti 12's were too much for me (too much sound not money)Anyway,I liked the 10's.I never listened to the lsi's,but would lsi 9's compare to the rti 10's.Price of them are close,so money is not an issue.right now I have older polk bookshelfs(rti28's).should I go with the rti 10 Towers or lsi 9 bookshelfs.I 60\40 music\ht room size-13x26 with 9 foot ceilings
Post edited by mailman23 on
Get lsi's. They kick ****. Better for hT and music. Just dont try to run them with some Panasonic HTIB receiver.
There is a reason why Polks top of the line is called the top of the line, and thats because its their current top of the line. It is better than the mid line AND the bottom of the line.
This means the LSi is better than the RTi AND Monitor, while the RTi is only better than the Monitor...
So yes, the LSi will be better, but they need an amp or a high quality receiver.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
the lsi 9's will produce as much and enough sound to fill the 13x26 area.More so than the floor standing rti 12's?
mailman23 wrote:the lsi 9's will produce as much and enough sound to fill the 13x26 area.More so than the floor standing rti 12's?
Not more than the 12s but enough for your room at decent levels...............but the quality of sound is better. Most describe it as smoother and more natural.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
that's not what you originally asked.... you wanted to know which was better the RTi12's or LSI 9's. not which will produce as much or enough sound.. both will do it, just depends the level of quality you want to attain, and do you have enough power to drive the LSi's.
I sometimes make my speaker decision by do i want bookshelves or do i want towers. that narrows my decision.. and make it somewhat easier. we can't tell yo what to buy, it's your decision and your home theater.PolkFest 2012, who's going>?
RTi will be perfectly fine if you do mostly home theater, but since you seem to do mostly music, trust us. get the LSi's, and very good amplification. go used for the amplification if need be.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
I agree with that much time spent listening to music the Lsi would be the better choice. Going with the 9's would be a great choice, however you should invest in a nice sub for the bottom end, as they will not have as much bass as a tower. And, like everyone said, only do it if you can drop the coin to amplify them properly.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
Mailman,
You have a PM -
The LSi are superior to the RTi and I feel that only a minority believe otherwise (and some of those havent even heard the LSi in a proper system). I feel tha the LSi will give you a more realistic vocal reproduction and a smoother midrange along with airy highs that very rarely detract from the sonic reproduction.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
what he said,,^^^Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
If you're going to use a receiver ie. Yamaha, Denon, Marantz, Harman Kardon...go with the RTI's you don't have the electronics otherwise to drive the LSi's.
