I got a ques about speaker wire hookup
GoMets17GoMets17 Posts: 5
hey,
Can anyone help me out with this. I am replacing the dash speakers in my truck. However, on the old factory speakers, the terminals are marked A, B instead of positive, negative. THey are crappy delco factory speakers. Does anyone know what the A and B is or how I can tell???
thanks
Post edited by GoMets17 on
  • hoosier21hoosier21 Posts: 4,392
    edited August 2002
    try the car audio forum below for better answers. I was up on car installs but that was back in High School. I have seen wiring kits at auto parts stores and Crutchfield that let you just plug the new fit to the factory harness, painless and easy and cheap enough, good luck
    You need something like this
    http://www.sounddomain.com/sku/SCOGM02B
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    edited August 2002
    some memory is coming back, doesn't GM use the same color for each channel and one of the wires has a black stripe?
    A = fronts, and has 4 wires two colors (2 blue and 2 purple)
    B = rears, and has 4 wires two colors (2 green and 2 brown)
    each set of 2 wires of the same color, one of them has a black stripe, the striped wire is the negative.
    edited August 2002
    maybe my colors are wrong, look at this
    http://www.datascape.net/99z28/stereo/wiring.html
  • GoMets17GoMets17 Posts: 5
    edited August 2002
    You are dead on with the colors. THat helps a lot. I understand that know, the thing is that there are no stripes on any of the wires. the only way I can tell which is positive and negative, is by looking at the speakers terminals. And it only is marked a and b. so I still need to know which is which
    edited August 2002
    THanks a whole heck of a Lot!!!
    that explains everything.
    you are good
    edited August 2002
    I stayed at Holiday Inn last night
  • nascarmannnascarmann Posts: 1,464
    edited August 2002
    Express!
    :D hoosier.....maybe you need to patrol the "on the move" forum....:lol:
    Oh, the bottle has been to me, my closes friend, my worse enemy!
Howdy, Stranger!
