so long outlaw 990.....
sickicw
sickicw Posts: 456
edited January 2006 in Electronics
Yup just did it. My 990 is now on ebay. I know it is a great preamp, but in the end I just couldn't get over fact that there was no auto eq (or any eq ) built in and my weird room dimensions and lack of space to move the speakers around pretty means I have very little options as far as getting a natural frequency response.
I know they were talking about adding it as an software upgrade (it already comes with a microphone), but I got sick of waiting and went out and bought a cheaper onkyo that had an auto equalizer feature.
Anyway, if anyone is interested go take a look.
Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
Post edited by sickicw on
  • Early B.
    Early B. Posts: 7,900
    edited January 2006
    A couple of questions --
    Did you try using an SPL meter? These inexpensive meters (and your ears) work just as well and should be used in conjunction with or in lieu of auto eq.
    If you've got weird room dimensions, you'll need something more sophisticated than auto eq. to improve the sound.
    Did you consider offering the 990 on this forum for sale?
    "God grooves with tubes."
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2006
    Dumb, just plain dumb.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited January 2006
    did you ever try to set the delay timing for your speakers, or was it a question of timing, but "bumpy" frequency responce?
  • danger boy
    danger boy Posts: 15,722
    edited January 2006
    OMG! I so want a Outlaw 990 pre. I've been looking closely and reading up on this pre amp. it's where i want to be for my HT system. I don't need no stinkin auto eq feature. i know how to set it up the old fashioned way. :p
    Sorry it wasn't to your liking.. I've read good reviews on it and the step down from that the 970 pre. Which is where i'm now heading instead.
    What are you looking to replace it with? Just curious.. so we can flip you **** ;)
    PolkFest 2012, who's going>?
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    edited January 2006
    no offense but that seems kinda silly
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
  • shack
    shack Posts: 11,154
    edited January 2006
    Pretty much says it all...
  • jrlouie
    jrlouie Posts: 462
    edited January 2006
    Damn, I wanted at 990 also! Probably had planned on getting one within a month.
    Too bad I'm at work and they block out ebay.
  • Early B.
    edited January 2006
    Sickicw -- since there are no bids on your Outlaw yet, pull the ad, return the Onkyo and we will gladly help you set up your system the right way. It is painful for us to read your post because the reason you purchased your Outlaw and separate amps was to get better sound than virtually receiver on the market, so we don't understand why you're going backwards.
    Auto eq on receivers is simply a marketing gimmick. Some of them work better than others. There's no need to make a purchasing decision on something as insignificant as auto eq.
    In terms of your weird room dimensions, we can help you out there, as well. If you could provide us with a detailed description of your room, including room size, system layout and some pics, we can make some recommendations on how to make your room more "frequency friendly."
  • ohskigod
    ohskigod Posts: 6,505
    edited January 2006
    WOW....I'm stunned here.
    my outlaw 950 has great auto eq. its called my ears and the remote control :D
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • McLoki
    McLoki Posts: 5,231
    edited January 2006
    Just to throw out another option that would be similar to your 990 but with the auto eq - the Sherwood Newcastle P-965.
    It has a PEQ for all 8 channels. (I think the eq can be adjusted or defeated for different inputs as well, but I am not sure on that feature).
    I have gone back and forth for the 990, the Sherwood, and a Rotel 1068. I keep going back to I have heard a rotel (1066) on my system and it sounded great, so that is the direction I am most likely to go. My current setup just has a good synergy with Rotel. (it may with other pre-amps as well, but I know the Rotel went well with it.)
    Michael
  • sickicw
    sickicw Posts: 456
    edited January 2006
    yea, i looked into the sherwood pre amp, and i really wish i would have gotten it in the first place, but it is quite a bit more expensive and you had to pay $100 to add the SNAP (auto eq feature).
    I do have a SPL meter and test cd, but it doesn't help too much unless you have equalizers to correct the problems. Like i said i dont have many options as far a speaker placement go. However, if anyone has any sugestions, i am listining.
    I also used an eq on my sub, but got sick of testing, ploting in excel, and adjusting especially when the auto eq sounds better. As soon as i set up my onkyo, my brother commented on how my new setup sounds just like a movie theater.
    I will probably take another shot at just a pre amp down the road, but for now my cheap ($500) onkyo will do (I am trying to save money for high def tv and/or blue ray player).
  • danger boy
    edited January 2006
    Don't feel bad.. one of my friends last year bought a B&K Ref 50, and has used it maybe 10 hours in the past 6 months.. it's currently sitting in a box in the spare bedroom. He doesn't like the video switching on it.. so there sits a $2K pre doing nothing but collecting dust. (and no, he wont' sell it to me either) :mad:
  • McLoki
    McLoki Posts: 5,231
    edited January 2006
    Still have to pay for the SNAP feature, but the sale of your 990 may get the preamp....
    Just a thought.
    Michael
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2006
    Wow!!!!! :eek: :eek: :eek:
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • McLoki
    McLoki Posts: 5,231
    edited January 2006
    Wingnut - would that be wow at the pre-amp sale, the 990 sale, or the thread in general?
    Michael
  • Early B.
    edited January 2006
    If your cheap Onkyo receiver sounds better than the Outlaw, then either the Outlaw was faulty or you didn't set it up correctly. Based on the above statement, I'd surmise the latter.
    Anyway, enjoy the Onk.
  • Sami
    Sami Posts: 4,634
    edited January 2006
    Hey, pull the ad and return the Onkyo, I will trade my HK AVR7200 for your 990... :)
    I'm in Keller BTW, just north of Fort Worth, no need to ship anything.
  • danger boy
    edited January 2006
    I don't think it was a sound problem with the Outlaw 990 he didn't like, more so than he really wanted the auto eq feature in it.. i think he was happy with it otherwise. I could be wrong though.
  • del44
    del44 Posts: 686
    edited January 2006
    Some people like to do upgrades and some like to do downgrades. It's all good! :eek:
  • wingnut4772
    edited January 2006
    I am just amazed that the 990 is going back for an Onkyo..but Hey! That's what makes horse races, right? Enjoy it. After all, that's what it's all about. Lord knows I have done some crazy things with this hobby.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • sickicw
    sickicw Posts: 456
    edited January 2006
    This is only a temporary downgrade for me (hopefully). Must save money for the next year or so for the following-> Payoff Honda Lawnmower debt, 1080p High Def TV, Playstation3 with blueray, and last but not least a new pre amp with Dolby TrueHD and DTS HD decoding, hmdi 1.3, and auto eq. Might have to throw in a new amp somewhere in the picture before the preamp, but you get the idea.
    VR3 Posts: 29,418
    edited January 2006
    I dont know what to say about this...
    So backwards in so many ways.
    What do you think is going to happen when you go from a high class preamp to a lowly receiver. You're going to need ALOT more than an EQ to correct that "problem."
