Class of amplifiers
Midnite Mick
Can somebody explain to me the different classes of amplifiers and what they mean. Still learning. Thank you!
Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote
Consonance cd120T
Usher CP 6311
Post edited by Midnite Mick on
aaharvel wrote:
Thank you sir.Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
think my Mosfet 5300 is class A, whereas the bi-polar 7300 is class B or class A/B. Heiney's the expert, he'd prob. know.
aaharvel wrote:think my Mosfet 5300 is class A, whereas the bi-polar 7300 is class B or class A/B. Heiney's the expert, he'd prob. know.
I was thinking of buying the 5300. how is itModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
oh it's great. Smooth, relaxed mosfet sound. I popped the top of mine last weekend and was jawjacked. There's one on e-bay for a stupid $150, so there might be a catch.
If not well- like I said... just stupid. -
not sure if smooth and relaxed is what i would like. Could it be interpreted as "dead" soundingModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
not really. Dead is dead. I attribute it to warm, laid back, smooth.
Sounds like you're a fan of the bright, aggressive type sound. What gear do you have? -
i have just purchased a set of lsi15's and I did like the sound in the audition of them. However, i felt that they weren't being pushed to their potential as in the audition he was just using a higher end hk with no external. They sounded great to me "very real". However, to be honest i felt that the bottoms were lacking a bit, but I felt that I could fill them in later with peripherals and possibly adjust the frequency slightly. But the mids and highs to were perfect.Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
Also he did mention at the time that the audition room didnt seem to be condusive to bass. He added a sub to the sound and it didnt make much difference. So I do believe himModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
well one 5300 would drive 2lsi15s well. 125 high current watts X2. into 4ohms.
BUT- get two of those f--kers, prob. around $400 total on the bay- and then you're pushing 250x2 on those lsi15's.
that'd be sweeeeeet!!!!!! -
Sorry I made a mistake. I was planning on getting the 5303 (3 channel for the front end)Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
whats your thoughts on that?Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
I must be getting tired! 5503Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
Sorry I have to leave. I don't want it to look like I am snubbing a question u might have asked. But I would really like to read what you think later. Thanks AAModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
I don't find the LSi15's to be lacking in bass. They pretty much do it all in my system, though I do have a small room. If you don't mind sticking with two channels, I love my Alta Vista modified Counterpoint SA-12. The unmodified one sounds pretty good to start with. Also, Here's one on EBay
http://cgi.ebay.com/Counterpoint-SA-12-Tube-Hybrid-Amplifier_W0QQitemZ5859871705QQcategoryZ39783QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I have put $2500 in mods into mine and feel they elevate the amp to a level I've never owned before. Still, for $400, the stock form is a pretty amazing amp.
HOME: VPI Classic/Grado Reference Master, EVS-modified Oppo BP83, Bryston DAC, Counterpoint 3000/SA-100 modified by Alta Vista, Polk LSi15
TRUCK: Pioneer 8600MP, Soundstream 300SX, pr of Xtant 1001i, Autotek SS490.2, Polk SR6500, Polk MMC6500, pr of Polk MM2084DVC -
Well thanks for the title aaharvel, but I'm hardly an expert. I just do alot of reading. Both are what would be considered class A/B. Although I suspect because of the properties of Mosfet's (5300) it's probably biased to run in class A a bit longer (perhaps as much as 10-15watts) before switching to A/B. Whereas the bi-polar counter part is more likely in the 5-10 watt range.
See article for a more indepth explanation
http://www.1388.com/columnists/jon_faq_amp.htm#21
Adcom's are very solid pieces and benefit from the simpler is better design perspective. All Adcom's have only 3 gain stages, while most other amps have 5 or more. They don't employ any current limiting circuits, just internal PS DC rail fuses. They have very robust output sections and ample PS to really drive low impedence loads and give lots of headroom.
As far as Mosfets vs. Bi-polar. I perfer the Bi-polar designs as they seem to be more articulate have a more solid bottom end (lots of control over the drivers). But really the difference is very slight. Bi-polars may show other weakness in you up stream components more so than Mosfets. Really for the cost Adcom's are a very solid choice.
If you are really interested and have time (or are bored) here is a great link explaining the basic principles of all popular types of amplifiers.
http://sound.westhost.com/amp-basics.htm
EDIT: Ignore all the technical/mathematic stuff in the above article. If you are worried about understanding EVERY little thing in the article you might miss the big picture. Just getting a general idea of how current, voltage, ohm and watt relate in the most general sense is all that matters.
FWIW
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
