Thoughts on this budget 5.1 system please.
Brewman
Brewman Posts: 12
edited January 2006 in Speakers
Hi all, I've been having a blast trying to put together a decent system for a HT. I am replacing a 14 year old Panasonic unit with 32" towers (8", 3.5", and 1" in each). The room this new system will be going in is 19'x13'x8' with the seating and Entertainment Unit on the 13' walls. The system will be used for Movies/Gaming/Music (50/40/10) but I do watch concert DVDs so music may be increased. I'm trying to get away from the towers and go for a cleaner look, so I want to go with bookshelf speakers.
I've decided on Polks for the speakers. Here is the setup I am thinking about:
Receiver: Onkyo 603X (Some may think this is overkill, but I like it due to the ability to add to it if/when we build a bigger house)
Fronts: RTi4s (or Monitor 40s, wasn't sure if they would be too much for the room, size and sound wise)
Center: CSi3
Surround: R15s
Sub: Dayton sub-120
That setup comes in at roughly $1200, depending on who has what on sale.
Any thoughts/opinions would be greatly appreciated as I have been out of this type of audio stuff for a long time. Thanks!
Post edited by Brewman on
  • danger boy
    danger boy Posts: 15,722
    edited January 2006
    just figure in a few more $$ for cables and wires and you should have a pretty decent system there.
    PolkFest 2012, who's going>?
  • TroyD
    TroyD Posts: 13,124
    edited January 2006
    Yup...rock on.
    BDT
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    edited January 2006
    FXi3's for surrounds would be a worthy upgrade im thinking but sounds good otherwise.
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
  • Willow
    Willow Posts: 11,219
    edited January 2006
    Seems like you are going in the right direction. I would opt for the Rti4's (great speakers) I would even go as far as saying if you swing it get another pair for the rears. Also as mentioned don't forget cables.
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2006
    right on.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Brewman
    Brewman Posts: 12
    edited January 2006
    Thanks for the opinions, I was worried that the speakers I selected might not fill the room, but I guess not. The FXi3s that Stopher mentioned are pretty nice, will have to keep those in mind for later down the road.
    Also, I would like some opinions on the Dayton sub. Would a 10" Velodyne ( or another 10" sub) fill the room sufficiently? The Dayton has no input to hook up to from the sub pre out on the receiver, so how would you connect it, with a Y adapter?
    Sorry for all the questions, there is almost too much info out there and too many choices, lol.
  • crazy
    crazy Posts: 443
    edited January 2006
    Why not get the Monitor series?
    Monitor 50 -- $400
    Monitor 30 -- $200
    CS1
    $180
    PSW10
    $240 (it used to free with $400 purchase not too long ago)
    Total = $1020
    Monstor cables for the setup ~ $100
    Onkyo TX-SR603X ~ $360 on Amazon.com
    Add the Onkyo 603 and you get a really really good system for less than $1500
    Distant Dream - A New Beginning
    www.distantdream.com
    (Now also available on iTunes)
  • ohskigod
    ohskigod Posts: 6,505
    edited January 2006
    the monitor is a good line, but some find it a bit bright. I heard them sound great, I've heard them sound bright too. I believe he might be a little better off with the RTi line, expecially with that reciever.
    If I had to play devil's advocate, I would say search that budget to see if you can find the money for RTi6's instead of 4's. just a little more oomph for the mains. if you cant, you still put together an excellent budget rig, all new stuff too.
    I hear good things about those dayton subs, get a lot for the money. that set up will do you just fine. welcome aboard!
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • ohskigod
    edited January 2006
    Monster = waste of cash
    that system, you can get the dayton line cables from partsexpress and be fine. if you need to get them in a store fast, than go with Acoustic research (the blue cables, not the pro line) budget wise and performance wise will fit that system you put together to a t. same performance as the monster, less cash.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited January 2006
    Very nice setup. You'll surely enjoy it.
  • Brewman
    Brewman Posts: 12
    edited January 2006
    Thanks for all the info guys, I really appreciate getting clear answers compared to a couple of other boards I've been on. Guess it helps to ask the right people. :D
  • crazy
    crazy Posts: 443
    edited January 2006
    Shizelbs, which setup is nice?
  • ohskigod
    edited January 2006
    both are solid entry level, the RTi and the monitor set up you mentioned
    if it sounds good to your ears, then its good enough.
    youll both catch the bug and upgrade through the years anyway, so your both at good starting points :)
