SS amp upgrades - what to expect?
adam2434
With speakers it's pretty easy to characterize differences, preferences, etc. among various makes and models at various price points.
With amps, I have so little personal experience with different makes, models, and price points, that I don't know what to expect and look for as I move up the food chain (as finances allow).
So, the question - assuming current delivery capability is not a primary deficiency in your amp, what kinds of performance gains to you get when you upgrade to higher price/quality ss amps?
Better detail/resolution, soundstage/imaging, tonal balance, etc.? I have no idea.
In my specific situation, I noticed significant improvements when I upgraded to 2 cheap monobridged Audiosource amps from a Pioneer Elite receiver. The AS amps would probably be considered junk to most. So, I'm wondering what an Adcom, Parasound, Rotel, etc. would give me in terms of performance gains over the AS amps.
Thanks,
Adam
Thanks,
Adam
5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5.
Post edited by adam2434 on
Better sound.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
the Audiosources are ok at there price point, but any of the names you mentioned will be a noticable step up. not just in sound quality, but headroom as well (push em a little harder without breakup or clipping)
I never heard adcom, but I heard parasound and Rotel. Like em both, I lean toward Rotel for home theater but its a toss up for 2 channel between the 2.
go used to start, you'll get far more for the money if your on a budget.
If your using the reciever as the preamp, might want to add a dedicated pre/pro to the mix. that will be a significant jump as well. The Outlaw offerings are pretty good (I got the old 950 and love it) Grab one of them used and you will quickly notice the difference.
have fun
Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
lord knows, your fine in the speaker dept for a while. those LS90's like good amplification. hence the difference going to the audiosource, and more so with the likes of Rotel, Parasound.Living Room 2 Channel -
RuSsMaN wrote:Better sound.
Thanks Russ, I'm cleaning the beer off my keyboard that I just sprayed when I read your response.
I certainly can't argue with that reply.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
Kitchen: Sonos Play5. -
One of the things I noticed when moving up the amp chain thru the years, was what appeared to be a lack of bass. What it was in reality was a tighter, more controlled---and deeper bass. This can take some getting used to at first until you start noticing the benefits of bass that is being reproduced realistically, with tonal accuracy. Better amps tend to lose high frequency grain as well, but of course this will depend on what you ultimately buy, and everyhting else in the audio chain...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
steveinaz wrote:One of the things I noticed when moving up the amp chain thru the years, was what appeared to be a lack of bass. What it was in reality was a tighter, more controlled---and deeper bass. This can take some getting used to at first until you start noticing the benefits of bass that is being reproduced realistically, with tonal accuracy. Better amps tend to lose high frequency grain as well, but of course this will depend on what you ultimately buy, and everyhting else in the audio chain...
Agreed,
As you climb the amp ladder, you will notice tighter bass, blacker background, less hiss, better vocals, seperation etc...Of course it all depends on the speaker you run and if they mate well with the amp you choose. AS amps are not bad, there are just better choices out there for a little more $. Check out the used market for some great deals. Also some amps are more "musical" than other. Some are better for HT.
Venom -
Thanks for all the input. I've always been attracted to Parasound gear for some reason. Perhaps I'll start looking around for used.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
Adam, you have a wide choice of Parasound amps to choose from right now on Audiogon.
Check it out! I love my 1500A.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
cfrizz, thanks for the heads-up.
A Parasound 1500A should have enough juice for my LS90s too, right?5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
At 205 watts I believe so!
Go for it & enjoy!!!!
So did you get one of the Parasounds on sale over at Audiogon? :cool:
Nah, I haven't made any decisions yet - really in the early stages of looking and researching (and saving).cfrizz wrote:So did you get one of the Parasounds on sale over at Audiogon? :cool:
