HK on screen display, cant see
edited January 2006 in Electronics
Anyone who owns an HK receiver, mine is an avr435, any help would be appreciated. I cannot get the OSD to show on my set. I have analog video connected from my receivers out to the tv. I am clueless. But I am trying to do the EZset and I don't think I can without the OSD. Also should I do the EZset if I don't have rear speakers? Thanks in advance for any advice. I have really gotten some great advice on this forum.
Jeremy
Post edited by jtoddaz on
Welcome!
    edited January 2006
    The internet makes reading the manual the last resort doesn't it? I recall that OSD only works on certain video outs, but can't recall which one it works on. I have mine set to S-video and use it that way. I know it won't work on the component outputs.
    edited January 2006
    It only outputs on svideo and composite... so if you are only using component you'll have to adjust it.
    My Iron Man training/charity blog.
    HT:
    32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
    edited January 2006
    There should be a monitor out on the back of the H/K. Connect that to a video in on the back of the TV and switch the TV to that input...if you are using component connections.
    suds, suds and more suds!
    edited January 2006
    All the manual states that make sure the Tv is connected via the tv out on the receiver. It does state that you cannot use the component video outputs, so I connected the dvd to the tv with the components. The problem is that the tv only has 1 s video input, so i have the cable box connected that way, so the receiver is connected to the tv via the composite video cable, and i am now clueless!!!Maybe I should connect the tv to the receiver on video 2 instead of the tv out, any thoughts?
    edited January 2006
    H/K monitor OUT (yellow cable or S-Video) into Video In on the TV (video1, video2, etc.) You don't need OSD on to use EZ-set.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
    edited January 2006
    I have a H/K 230 receiver. Only the composite works for OSD. I have both composite and S-Video connected to my TV, and everytime I need to see the OSD, I have to disconnect the S-video in from my TV in order for the OSD to display.
    edited January 2006
    Just run everything through the 435. Run components from the DVD player into the receiver and then out to the tv. Run the cable box into the back of video 3 via a S-video cable and then run a seperate S-video cable from the monitor out to the tv.
    HK has a nice connection diagram that they include with the receiver or you can access it from their site.
    edited January 2006
    As per Kejolly, I run everything through my 335. I can only get OSD with composite and Svid. Not sure why not with component, but hey....not a big deal.
    edited January 2006
    I liked their diagram, but I was just following advice to put your video connections straight to the tv, not through the receiver. I don't know if their really is a difference in video.
    edited January 2006
    I haven't noticed any changes in video and my cable sucks so bad that I couldn't tell if I tried.
    I am happy with everything hooked up through the receiver.
    edited January 2006
    The OSD does work through the component on the 435/635.
    1) Do a receiver master reset
    If that doesn't work.
    1) Check Firmware
    2) Update Firmware
    3) Do a receiver master reset
    You might try actually trying the composite and s-video cables to video first. Then there is an option under the Input section to pass OSD through input you are configuring.
    GOOD LUCK!
    edited January 2006
    Thanks I will try.
Welcome!
Welcome!
