LSi's and Onkyo
  • kmartin971
    kmartin971 Posts: 236
    edited January 2006
    Cinema Grand Signature 400~seven
    400 watts rms continuous per channel, all channels driven into eight ohms from 20Hz to 20kHz with no more than 0.5% T.H.D.
    800 watts rms per channel into four ohms
    1600 watts rms per channel into two ohms - time-limited basis
    Two output options for the main left and right channels: current source for a warmer, more open tube sound or voltage source for all the tight response this awesome solid state amplifier can deliver
    Intrinsic frequency response 1 Hz to 80 kHz
    Signal present auto-on switch senses input signal on any channel and automatically powers up
    12VDC trigger input with 1/8" mini jacks as well as plug-in screw-terminal strip
    Balanced XLR and unbalanced RCA inputs
    High-quality gold-plated all metal five-way binding posts
    Five-year parts and labor warranty
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Side Rear (2) = LSiFX
    Rear (2) = LSiFX
    JBL S120P II
    Sony Upconverting DVD Player
    XBox
    XBox 360 (Wireless connection live and media center enabled)
    PS3
  • audiobliss
    audiobliss Posts: 12,518
    edited January 2006
    "Now thar's an ayump!" A good ol' Sunfire. I'd love to have one of those one day. Absolutely amazing specs. Doubles it's output down to two ohms. The stereo amps double their output all the way down to one ohm! :eek: And I've only heard good things about Sunfire.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • kmartin971
    edited January 2006
  • m-rorem
    m-rorem Posts: 58
    edited January 2006
    Yes great spec's good reputation, but now he's getting into some pretty serious $ even used. If your willing to spend this kind of $ you have many many many options available to you. Also, remember that for any amplifier to meet those kind of specifications they will most certainly have to have a dedicated 20 amp circuit available to them.
    mrorem
  • audiobliss
    edited January 2006
    Kinda seems inconsistent, I know. But when you combine the fact that Audiosource didn't specify the conditions under which they measured that 0.2% THD with the fact that it doesn't come close to doubling power when the resistance halfs, you don't get a pretty picture.
    With the Sunfire, the THD is rated full-bandwidth (20Hz-20kHz...that is full-bandwidth, right?) with all channels driven (and that's 7 instead of 2!) at 400 watts per channel. AND it doubles its output all the way to 2 ohms. Looks like a much, much more solid amp.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited January 2006
    Good point. It's also backed up by that ebay add...$4500...and it's only 200wpc! :eek:
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • kmartin971
    edited January 2006
    The AS only had two amps! lol~!
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • m-rorem
    m-rorem Posts: 58
    edited January 2006
    kmartin971 wrote:
    The Cinema Grand IV pre-pro has had mixed reviews, it is a definite step up from the previous generations, but for the $ that it demands you can do better. Also it's 19" (pro) form factor doesn't appeal to everyone, hope your equip rack can handle it.
    I have not personally auditioned sufire products in quite some time, so I can't comment on their performance only what I have read from other discussions.
    mrorem
  • audiobliss
    edited January 2006
    :confused: Not sure what you're saying there.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • kmartin971
    edited January 2006
    Read the comment above. The AS 300 only comes in two channel. You would have to buy multiple pairs.
    PS - The audio closet has two dedicated circuits - a 110 and a 220
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • kmartin971
    edited January 2006
    You are not comparing apples to apples here. The AS only comes in two channels.
    AMP300 Specifications
    Power Bandwidth 20Hz-20kHz:
    150W per CH into 8 ohm loads with less than 0.2% THD+N
    235W per CH into 4 ohm loads with less than 0.2% THD+N
    470W Bridged Mono into 8 ohms with less than 0.2% THD+N
    Crosstalk: >65dB @ 1kHz, ref. to rated power into 8 ohms
    Frequency Response: (20Hz to 20kHz)+0.0dB, -0.5dB
    Signal to Noise ratio: -103dB ref. to rated power into 4 ohms
    AC Power Consumption: 1200W (all channels driven)
    Net Weight: 28.6 lbs (13.0 kgs)
    Gross Weight: 36.5 lbs (16.6 kgs)
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • audiobliss
    edited January 2006
    I'm sorry for being so obtuse, but I'm not seeing the fault in my comparison. Somebody fill me in. :confused:
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • kmartin971
    edited January 2006
    If you buy multiple AS amps the rating will stay the same. AS 300 runs about $400 for 2 channels.
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • m-rorem
    m-rorem Posts: 58
    edited January 2006
    You disagreed with him! That's the fault! (LOL)
    Just kidding of course.
    Unfortunately all too many people get wrapped up in the spec's and don't take the time to audition before they part with $. Then again, this trend is what provides the "savy" pre-owned buyer a good selection of product to choose from, so I say keep it up america!
    mrorem ;)
  • kmartin971
    edited January 2006
    I auditioned the LSi many times before buying. I will do the same with my equipment.
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • audiobliss
    edited January 2006
    Ok, specify what 'rating' you're talking about, and I think we'll be on the same page.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • kmartin971
    edited January 2006
    THD rating - the AS 300 was also rated at full bandwidth. Re-read your post above #67.
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • audiobliss
    edited January 2006
    Right. The THD rating of 0.02% will be the same across the board, no matter how many AS amps you buy. But I fail to see how that is relevant the comparison I was making earlier.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • kmartin971
    edited January 2006
    Your post implies that if you increase/decrease the number of channels the distotion level will increase. Re-read 67.
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • kmartin971
    edited January 2006
    So I assume you are not for stacking the AS 300? 235WPC?
    LSi25 Recommended Amplifier Power 20 - 300 w/channel
    (Keep in mind the woofer already has its own amp)
    LSiC Recommended Amplifier Power 20 - 200 w/channel
    LSiFX Recommended Amplifier Power 20 - 200 w/channel
    Seems that should be sufficient.
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • audiobliss
    edited January 2006
    Sorry if my post implied that, didn't mean for it too at all. I was trying to say that the Sunfire was subjected to a lot more stress for testing than the AS (7 channels opposed to 2, full-bandwidth rating opposed to who knows what, and driven at full power as opposed to who knows what). Considering that and the fact that it is obviously very high current (doubles output down to 2 ohms) whereas the AS isn't (goes from 150@8 to 235@4), I deem the Sunfire to be a much superior amp.
    And I still think no one should use the AS in a home audio environment.
    EDIT - However, that is only my humble opinion. Treat it as such.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited January 2006
    But what about the LSi25's? That's what I've had in mind all this time. They'll handle 300 watts, and I'd give it to them.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • kmartin971
    edited January 2006
    I agree. But the Sunfire is 5k and 8 channels of AS can be had for 1200-1400.
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • kmartin971
    edited January 2006
    The LSi25 can be split. Whats left is an LSi9 (Recommended Amplifier Power 20 - 200 w/channel ). The 10" woofer already has a seperate dedicated amp.
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • audiobliss
    edited January 2006
    Great point. So scratch both the AS and the Sunfire and look into Parasound, Rotel, B&K, Carver, Adcom, NAD, etc. And don't forget Cinenova. I've heard a good bit of great stuff about them here lately.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • kmartin971
    edited January 2006
    Why would you not use AS? Just curious. I think its interesting that you would not use As in the home when thats all they do.
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • kmartin971
    edited January 2006
    I have lots more homework to do :) Thanks!
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • audiobliss
    edited January 2006
    Because, IIRC, it's regarded to be of the same quality as a PA amp, the specs don't rule out that view, and you can do better for the money on the used market. Start looking into amps from Parasound, B&K, Carver, Rotel, Adcom, Cinenova, NAd, etc. You could do great on amplification with something from any of those manufacturers for the same or less money, I'd bet.
    But, bottom of the line, use your ears. And for sure don't take what we say (me in particular! :p) for granted. Rely on your research and your ears. And enjoy!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • kmartin971
    edited January 2006
    I am going to look at parasound next!
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Rear (2) = LSiFX
    JBL S120P II
    XBox
    PS3
  • Dennis Gardner
    Dennis Gardner Posts: 4,860
    edited January 2006
    I would match quality of the speakers with quality of the amp. Some nice mid-fi brands that others here on the forum use are......Parasound, Rotel, Outlaw ATI, Odyssey all have nice lineups that would give your receiver the needed relief.
