Pioneer amplifier: noise when turning up the volume | dead left channels
u235vu239
I bought this pioneer amplifier (SA-408, similar to the SA-410, I guess), but it has two big problems:
1. when I turn up or down the volume, it makes this really nasty noise
2. it seems that it can't reproduce the left channel, as the whole "RCA lefts" seem to be dead (only the "RCA rights" can reproduce any sound)
Can someone tell me what I can do?
Thanks in advanced
Thanks in advanced
Post edited by u235vu239 on
does the nast noise come out the "dead" left channel?
all I got is, it sounds like..at the least... the volume pot is filthy. get some deoxit, or some kind of electrical contact cleaner and clean that bad boy.
spray behind the knob (unit unplugged) generously and then turn the knob back and forth as far as it will go either way at least 20 times. turn it on, hopefully it wont do the noise, or it will decrease. you can then see if it solves the dead channel issue. which might, or not be related. I'd start at the cleaning the volume pot before going anywhere else.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
ohskigod wrote:does the nast noise come out the "dead" left channel?
No, the the nast noise doesn't come out of the "dead" left channel.
Thanks for your help. -
if not, try the deoxit trick on the balance knob too. dont laugh, I had that same problem with a Denon PRA 1000 pre. when it was really dirty, nothing out of the left channel, but it did fuzz and sputter a little when you touched it. deoxit anyway, it cant hurtLiving Room 2 Channel -
check if that thing has got fuses too. I had an old sansui that had fuses inside the unit, only accesible popping off the top. If you do this, unit must be unplugged.Living Room 2 Channel -
ohskigod wrote:if not, try the deoxit trick on the balance knob too. dont laugh, I had that same problem with a Denon PRA 1000 pre. when it was really dirty, nothing out of the left channel, but it did fuzz and sputter a little when you touched it. deoxit anyway, it cant hurt
When I plug both right and left rca's to the amplifier and touch the ends that were suppose to be plugged into the cd player, only the right one makes that contact noise. The left one has no reaction. Could it still be a dirty knob?
Thanks for your help -
u235vu239 wrote:When I plug both right and left rca's to the amplifier and touch the ends that were suppose to be plugged into the cd player, only the right one makes that contact noise. The left one has no reaction. Could it still be a dirty knob?
Man...that's asking for trouble. Leaving those ends unattached while having the unit on is a bad idea, that's how things get eff'd up. I know what you mean by contact noise. Again as has been suggested check for blown fuses. The procedure you decribe can lead to blown fuses. Beyond the DeOxit and checking for blown fuses you may have to get it serviced.
FWIW
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
