Suggestions besides Sunfire Cinema Grand?
jrlouie
I'm highly considering a Sunfire Cinema Grand 200~5 for my Lsi setup. I'd like to ask suggestions for amps with the following criteria...
Thanks!
near equivalent power (200@8ohms / 400@4ohms)
apparently there is something to be said for an amp that doubles output at 1/2 the impedance and the sufire does that, so something similar there
equivalent (or better) in your opinion in quality
max price $2500 new or $1500 used
suggestions only for 5.1 Lsi setup (other speakers do not apply)
no taller than 8 inches
prefer 5-channel amp, rather than 6 or 7
Thanks!
Post edited by jrlouie on
no taller than 8", hard one there.
If you can do something, the earthquage amps are killer.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I was kinda in the same frame of mind when I bought my lsi speakers. An amp that can double the output as the impedance is halved is a very noticeable improvement.
My main concert was that I wanted to cross over my lsi9s at 60hz but when using my outlaw amp, the frequency roll off on the low end started way before 60hz, and their was a very noticeable gap between where my subwoofer started and where my lsi9 left off.
The lsi9 can dip down to 2.4 ohms, so that means I needed an amp that could double the power all the way down to 2 ohms. Now thats just not going to be possible on that kind of budget without being inventive. So what I did was bought the highest quality car amplifier that I could find, and hooked it up to a 1 Farad capacitor and a used (from ebay) 55 amp power converter. Worked perfectly. The only temporary problem is that it doesnt look quite as nice as a home audio amp, but that problem will soon be solved when I rewire it and put the power converter in its own case. Depending on what amp you buy, you could probably put it in a case along with the converter and cap that would be under 8 inches. Car audio amp are pretty thin, and the converter is about 5 inches tall.
Also, I did look into the sunfire amp (didnt listen to it), but decided against it because it is a class D amp and I heard many reviews about loud switch noise, static in speakers, and terrible at high frequencies (which makes since because it is class D).Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture. -
Only 300 watts though...
http://www.outlawaudio.com/products/755.html -
Oh and by the way for my other speakers (crossed over at 80hz), i use the onkyo 703 for the rears, and a outlaw 755 for my center only. Havent decided if Im going to add better amplification to the other channels yet. I mainly hooked up the onkyo reciever to my rears just so it doesn't get so hot being used only as a pre amp.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Sounds like the only other recommendation fitting my needs is the Outlaw. I actually was wanting the Outlaw before I investigated the Sunfire. Since then I've learned of the Sunfire's capabilities and kind of became partial to it.
The problem is, it is going to be hard to find a Sunfire to demo in my area. My only hesitation is statements I've read about noise on the amp.
Obviously, the Outlaw is online only, so that'll be hard to demo also. Although, I have two M200s. So if the 755 sounds like the M200s, then I already know what it'll sound like. -
Big surprise, but I'm gonna say: Bryston! You can probably find a used 9bST for that price and it'll hand the Sunfire it's ****, even though it's only advertised as 125 into 8 Ohm. Mine tested at 155 watts with 0.005%THD, so if you actually drove it to the 0.5% THD that Sunfire advertises, it's gonna be getting close to 200 watts. 5.25" tall or 3 rack spaces.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
This is an amp that I recently upgraded to:
www.gemstoneaudio.com
They have 5 channels within your price range. But be forewarned that it is massive! double-down to 400watts @ 4ohms. Class A - A/B
Please search for my earlier threads on the subject for a short impression.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
Sherbourn 5/5210?
I got the 7/2100 and love it.
Both are 200wpc @ 8ohms and 300wpc@ 4ohms min sine wave continuous output.(whatever that means I am reading straight from the owners manual)
Less than .05% thd@ 8ohms and .075%@ 4 ohms.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Oh yeah mine can be had for around $1500.00 used.
Edit.
Ok not "MINE" but the Sherbourn in general.
Also be forewarned it weighs 115#.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
I just want to say - if you can find one - Cinepro rocks. (and is 8" high)
6 channel amp - (you can bridge it to a 3 channel amp if you want to)
Output Power....... .350 WPC/8 OHMS (typ. 450W)
500 WPC/4 OHMS (typ. 670W)
1000 WATTS MONO (1400 @ 4 ohms)
Dynamic headroom... >3.5 dB! (Typ. 850 watts @ 8 ohms, 1100 watts @ 4 ohms)
Peak Current... 120 amps per channel (720 amps total) .1sec pulse, .5 ohms
Damping Factor ...Over 1000 (!) (10Hz-1kHz)
might want to look into a used krell amp as well.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
