Wtb: Pci133 Ram
Airplay355
Probably a long shot, but does anyone have a 256 MB stick of PCI133 RAM they don't need? I'll wait a day or so and then I'm just going to buy new stuff. Let me know. Thanks Polkies
Post edited by Airplay355 on
FYI, it's just "PC133". No "I".If you will it, dude, it is no dream.
Sorry, airplay... I don't keep any SDRAM around anymore. If I have any, it usually goes straight into a machine that's laying around or passing through.Ludicrous gibs!
I know I've got a single stick here somewhere. I can't remember how many Mb, though. May be 128, but I'm not sure. You can have it when I find it, if you can use it. I'll try to check at lunch.
Jason -
Thanks guys. It's ok if you don't have any. No biggie. Just figured I'd check before I dropped $45 on some RAM.
I found the one I was thinking about- It's in my father-in-law's computer!
Forgot that I put it in there. I DO have the 64Mb stick that I took out, and you're welcome to that-- But I'm sure you want something larger than that, if you're going to bother to upgrade.
Jason -
I think I have some but it's more on the line of 512, might even have 2 of them. Ya still looking?Front
Polk RT800i (BI-wired)
Rear
Polk RT600i
Center
Polk CS400i (BI-wired)
Sub
SVS 25-31PCi (22Hz tuning port)... it's SubHuman
Receiver
YAMAHA RX-V1400
TV
Mitsubishi WT-46807 HDTV
HD receiver
T i V o HR10-250
