All those used cables on Audigon / what's up?
  • Joey_V
    Joey_V Posts: 8,600
    edited January 2006
    Flash21 wrote:
    But I can't resist pointing out that differs somewhat from your previous statement:
    I wont buy into high priced interconnects, wire, powercords.... how's that for clarification? Good quality, fine. But I wont use interconnects to tweak my system ever. That's just me, but I can find better uses for $1000 instead of on a set of Audioquest speaker wires.
    But again... that's just me.
    If we're talking about $50-100 interconnects, count me in... but I thought this thread was about the mega-buck types.. and I dont roll like that.
  • Skynut
    Skynut Posts: 2,967
    edited January 2006
    I kinda agree there.
    I feel like they make a difference but not if they are too expensive.
    I have alot of money in wires but I have alot of wires.
    My interconnects are like $40.00 a pair + shipping and I have some nice power cables but they were only like $120.00 each.
    I am not willing (at this time) to spend $200.00+ for a pair of ic's when I need so many to hook up my system.
    Later (when I am rich) I would be willing to pay alot more just for fun.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • polkatese
    polkatese Posts: 6,767
    edited January 2006
    Skynut, I suggest to spend your money on IC where it will make a difference. For instance, I would never thought of putting MIT Shotgun on my HT system:1) too expensive, 2) with its passive network, it would be impractical and hard to do in my setup.
    I passed that point (the psychological barrier of over $200 i/cs) just recently. My new finding is: Synergy between cables: from power cord, to i/c, to speaker cables, is very critical, even more important than the individual cable itself So, from price-point perspective, it may not be as relevant as the consistency of brand-synergy within the chain.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Skynut
    Skynut Posts: 2,967
    edited January 2006
    I agree, all my cables are the same manufacturer.
    I would not be interested in mixing cables in a 5.1 system. Therefore I would need to replace 12 cables plus the sub at the same time to really compare.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
    F1nut Posts: 51,749
    edited January 2006
    Joey_V wrote:
    Why? Because speakers and amps yield a MUCH larger difference in sound than wire??
    Hmmmm.......could it be that you think that way because you've never tried high end cables? Bottom line is that every piece of the chain counts and that includes cables.
  • Joey_V
    Joey_V Posts: 8,600
    edited January 2006
    So are you saying that you would spend $1000 of your own money on a speaker wire pair instead of upgrading your amp? Lets not forget that this speaker wire pair may or may not work well "synergy-wise" with your next system, should you choose to upgrade.
    All I'm saying is that cables are the last things to tweak as they yield minimal changes to the overall tone.
    F1nut Posts: 51,749
    edited January 2006
    I just bought new cables with a retail of $1650.00 for my shop rig, so the answer would be yes. As for "mininal changes" I would have to disagree as they can be quite defining.
  • pjdami
    pjdami Posts: 1,894
    edited January 2006
    Audiogon is just a great place to buy used wire and dump it if you are not happy with it. I've spent up to $1,000 on used ICs and speaker wire from a very reputable (great reviews) company before and as hard as I tried to like it in one of my systems I could not get it to work out for me (sounded too dark) so I sold them after offering here on the flea market first.
    Synergy and what you like is what matters. Everyone is going to be different and have a different "standard" to how music should sound. I have kimber wire that I use on one system with great success but hate the way it sounds on another system. Does it make it sound bad?? Well no, but the tone changes particularly in the upper frequencies. Yeah, kind of subtle, but when you get used to how your system sounds and really listen it kind of matters to some folks.
    VR3 Posts: 29,425
    edited January 2006
    I buy cables for one reason and one reason only. (Aside from the fact Ive heard them make a difference)..
    And that is because I didn't spend 3,000+ to put 50 dollars worth of cables behind my setup.
  • read-alot
    read-alot Posts: 812
    edited January 2006
    And how can you question a guy thats got 10 thousand more posts than me and we started at the same time.
    BTW the MITs are staying, everyone including the Maltese lap dog can tell a difference for the better.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • Joey_V
    Joey_V Posts: 8,600
    edited January 2006
    And this shop rig.. what is it and how much did it cost you?
    If you say $2000 or less, you need to have your wallet taken away from you. If you say over $10000, then I can sort of see why you would spend that much and not flinch.
    F1nut Posts: 51,749
    edited January 2006
    Joey, Although I have a complete set up for the shop I'm replacing a few more pieces, so I'm not sure what the bottom line will be yet. However, that's not the point. I spend a lot of time in the shop, so naturally I want to enjoy that system and that is the point for all of us, right?
  • Joey_V
    Joey_V Posts: 8,600
    edited January 2006
    I understand that completely F1, it's just that I think that the cables should match the price of the system relatively. I wouldnt ever think of spending $2000 on cables on a $2000 speaker set. However, I wouldnt mind spending $100 on a $2000 set. That's just me though, you may be different.... after all, it's all in the name of enjoyment.
    F1nut Posts: 51,749
    edited January 2006
    I understand what you are saying. There is no rule of thumb, but some folks think that the cost of their cables should be in relation to the cost of the entire set up, not just the speakers. One thing I do know is that the better the gear, the more one is likely to realize the benefits of better cables.
  • madmax
    madmax Posts: 12,434
    edited January 2006
    Something I've found is that it is not totally related to cost. Generally the more expensive the amp and source the better it sounds with higher priced cables. However, I've had some fairly expensive amps which I could not tell any difference in what cables I use. But, I've had a few inexpensive amps where the difference is big. I think the rule of thumb is if you have the cash laying around you try what seems interesting and if it dosen't do anything for you and your system, you can always switch back to something less expensive until you change things around next time. I have found you cannot try it once and make a lifetime conclusion that it matters or not.
    madmax
    Vinyl, the final frontier...
  • LuSh
    LuSh Posts: 887
    edited January 2006
    Hmmm I can understand why people trade in and out cables so often. Joey_V if somebody actually explained it to you you might think differently. Cables and other tone controls are much easier trying out then say amps and speakers. Try buying and selling then shipping 4 amps over a year. It's not fun. PC, Interconnects and Speaker wire is much easier to ship. In some cases a $1000 interconnect might be as big an upgrade as $1000 spent on an amp. Keep in mind few people on Audiogon actually buy new.
    Most people buy used, then upgrade and sell off their old cables. After a year or two you gradually go from using pretty entry level stuff to using pretty good stuff and only spend a couple hundred here and there. Some cables, like the current Audience Masetro speaker wire I'm using has slowed my want to upgrade my speakers.
  • Skynut
    Skynut Posts: 2,967
    edited January 2006
    I have read several different places that if you are planning to build a system from scratch that the "rule of thumb" is 10% of the total cost of the system should be considered for the wires.
    This is just a starting point and I believe is intended to make people remember that wires are going to need to be purchased and are improtant.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • Ferres
    Ferres Posts: 310
    edited January 2006
    In my personal experience, wires do make a difference. But as prices go up, the benefit/price ratio gets lower. I settled on not spending a certain amount for cables.
    I have settled on the lsi9 as my mains. I like the fact that every few upgrades I make gives more life to these speakers.
    Cables have very long burn in times, safe bet is 2 weeks to find their optimum effect. So sometimes, the pay off comes a bit later with use. :D
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • Skynut
    Skynut Posts: 2,967
    edited January 2006
    Compared to everything else in the system cables seem like an easy thing to swap out.
    If you don't go overboard on price there is always the option of holding onto any cables that are worty of trying again if you change out another component.
    If I spent over $200.00 on cables and did not like them they would be sold off.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
