Optical vs Coaxial
limashaynut
Up to now I have always used a optical digital hookup for components over coaxial when given a choice. This is based on my ASSUMPTION that the optical was the higher quality hookup. I saw a sugestion in the owners manual of a Sony ES AVR recently that sugested using the coaxial over the optical, and was just wondering if my previous assumption was correct. So how about it, which is the better of the two? Is it six of one, half a dozen of the other? Which hookup would most of you guys use? If one is better than the other, then why?
BTW, I did a search to see if this topic was covered in a previous thread, and did not get any hits.
Jerry
Denon AVR-3806 7.1
Outlaw Audio M200 (RF,C,LF)
Sony KDFE42A10 LCD
Directv H10-250 DVR
Sony DVP-NS90V
Sony RDR-GX315
JVC Super VHS
Polk RTi8 m
Polk CSi5 c
Polk RTi6 sr
Polk Monitor 30 srb
Polk PSW505 sw (I know, I know, get an SVS!)
PLUCK THE CHICKS!
From A Former Fan
Denon AVR-3806 7.1
Sony KDFE42A10 LCD
Directv H10-250 DVR
Sony DVP-NS90V
Sony RDR-GX315
JVC Super VHS
Polk RTi8 m
Polk CSi5 c
Polk RTi6 sr
Polk Monitor 30 srb
PLUCK THE CHICKS!
From A Former Fan
Post edited by limashaynut on
no difference between the two, UNLESS you're making extremely long cable runs that might be susceptible to electronic interference. That's a big unless but in that case- go with the optical.
either is fine.. go with what you have already. don't ponder this at all. it's not worth even thinking about it.. coax or optical.. both are digital. does the same thing basically. some people prefer chocolate milk, other people prefer white milk. same thing.. both are milk right?PolkFest 2012, who's going>?
I use the digital optical ..
It seems to be better to me on what I`m running...
I swapped to coax and it seemed duller to me at the time, so I never took the time to experiment again after that...Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
The only drawback I find with optical is that their very easy to get loose. Doesn't take much to accidentally dislodge it.
Personally, I did not find much of a significant difference between the two.Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
Conditioner: Isotek
The main differance between optical and coaxial cables. Is that optical cables don't make an electrical connection between the devices.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
As with all cable/wire debates, there is no clear winner. The difference between the two may be nonexistant to some and quite obvious to others. The only opinion that matters is yours. Both cables are inexpensive, so get one of each and try them with a piece of music you are very familiar with, you might be surprised at what you hear.
Report back with your findings so we can flame ya, or call you an Audio God!!
If your a history buff, here's some light reading on the subject....
Search Results -
I think otherwise.............WHITE milk...........aaharvel wrote:oh come on... :rolleyes:
Chocolate milk is SOOOO much better
LINK is below
http://www.polkaudio.com/forums/showthread.php?t=32586&highlight=optical+digital+coaxGodspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon -
I like the RG6 because I can make a pretty, custom length cable, down to a foot long, with solid connections, in about 2 minutes.
Thanks for the feedback, kind of what I thought, pick your flavor!
BTW, between the white or chocolate, I like both, depends on my mood or what I am eating with it! :rolleyes:
I think I will stick with the optical, that way if I want to upgrade my mutant seabass with feakin laser beams on their heads, I can do it!
Jerry
Denon AVR-3806 7.1
Sony KDFE42A10 LCD
Directv H10-250 DVR
Sony DVP-NS90V
Sony RDR-GX315
JVC Super VHS
Polk RTi8 m
Polk CSi5 c
Polk RTi6 sr
Polk Monitor 30 srb
PLUCK THE CHICKS!
From A Former Fan
