Y splitter hook up
doug lang
Going to try a splitter to gain more volume with my sub. Do I split it on the pre amp or the sub. Not sure where the splitter should be put. I am trying this to power on better my sub. The sub is a Vel dls 5000. I have contacted Velodyn and they suggested this as a fix. We will see. Thanks Doug
Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables
Post edited by doug lang on
If there is only 1 subwoofer out on the receiver, use the y-adapter there.
The Velodyne should have both a Left & Right input. A Splitter there would be irrelevant. -
The use of a Y splitter is optional. Y splitting a LFE signal will allow a hotter signal to be inputted into the sub, however it is not going to change the maximum capacity of the sub. Using a Y splitter will be similar to bumping the volume control on the back of the sub slightly. If you're looking for more output, I would consider moving the subwoofer around the room, or buying a second, identical subwoofer.-Eric
-Polk Audio -
Hey Eric Eric I was trying to get more imput to my sub. It was not powering on unless I increased the volume. I have the splitter and I will give that a try. Thanks DougOppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
Wow, never heard that one before.
My initial thought was that I would repair the problem with several M-80's and a match. Not very cost effecient though.
I guess if the Y-split boosts the signal the amp will pick it up, some type of impedence mismatch from your receiver I presume.
RT1
RT1
