On line investing?
madmax
madmax Posts: 12,434
edited April 2024 in Clubhouse Archives
Anyone do this? I set up an Ameritrade account and bought some stocks. Nothing serious, just for fun. Had to have some of that GM stock...
madmax
Vinyl, the final frontier...
  • PolkThug
    PolkThug Posts: 7,532
    edited January 2006
    madmax
    I've done it before, its a pretty fun way to make a little pocket change. Just make sure you read all the guidlines about fees (ie make x number of transactions a month and there is no fees, etc).
  • Shizelbs
    Shizelbs Posts: 7,433
    edited January 2006
    I think I am about to pull the trigger on Scott Trade. $500 minimum set up and $7 trades. No inactivity penalties. Seems like a pretty fair deal. I pretty much don't see myself as a day trader, just make a few trades every month or so and let them simmer.
  • PolkThug
    edited January 2006
    Sounds good, if you're low volume trading, just remember a few basics.
    At $7 a trade, the total cost of buying and selling is $14. So, I wouldn't buy less than 14 shares of anything. For 14 shares of any stock, the price per share has to go up at least $1, before you can make a penny.
    This is just a guideline I use for minimums, keeps things simple. If you buy too few shares, you're at higher risk because the market has to move more for you to make a gain.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2006
    I have been buying stocks on line that you dont need any broker, seems to work well for me. Several Companies do this.
    RT1
  • Skynut
    Skynut Posts: 2,967
    edited January 2006
    Ameritrade here.
    Just for fun and only with cash I can afford to loose. (not much there right now)
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
