"Your speaker levels should never be in the +."?
brijenjas
brijenjas Posts: 311
edited January 2006 in Speakers
Said by Vr3MxStyler2k3,
in this thread, http://www.polkaudio.com/forums/showthread.php?t=35447
2nd post.
Forgive my ignorance, but why is this so?
Is there a danger of damage to the speakers or AVR with these settings?
Is the sound less bright/more warm at the "-" settings?
I haven't heard the difference with the settings below.
I thought the the speaker levels were adjustable in the receiver to achieve even sound, whether you had to raise or lower the levels.
I had my L/R mians at +3 because of how much louder my center channel sounded, I have since turned them back to 0 and reduced my center to -3.
I have the same "equality of sound" so to speak at these settings.
Post edited by brijenjas on
    VR3 Posts: 29,427
    edited January 2006
    Theres no real advantage...
    Some theorize that putting the levels below 0 (or starting them there) allows the preamp stage to process a cleaner signal.
    I recomend it to everyone...
    it is MUCH better to start out with -5 on the mains and get like +1 on the surrounds... than start with zero on the mains and get like 6+ on the surrounds...
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2006
    Where you start has nothing to do with it. The whole purpose behind calibrating a system is to achieve equal SPL at a predetermined volume level. The Dolby digital standard is 80db and thats typically the reference level for most, if not all receivers that display a DD logo. Yes there are exceptions, my preamp for example, allows me to select any volume level I want as a reference level and then I can calibrate to that point. + or - means nothing, whats important is how close each speaker is to the reference level.
  • brijenjas
    edited January 2006
    Thanks for the replies.
    I suppose i should borrow a meter to measure the SPL.
    A related question. I use amps for my main speakers, I have the amp volumes set at midpoint and adjust the speaker levels with the receiver,is this the correct way to do this?
    Or is this a trial and error scenario, where I find the sound I like and set it there?
    If I set the amp volume too high I'm sure I will get distortion.
    Thanks again.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2006
    Well all my speakers ended up being at or under 0 after SPL calibration with the exception of the back two (+1) and the sub (+2 at about 3db hot) so I guess I am ok.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • danger boy
    danger boy Posts: 15,722
    edited January 2006
    my center and surrounds are often calibrated in the low + numbers.. the center more so than the surrounds.. it's not unusual for my center to be + 4 or +5 with surrounds around +1 or +2
    PolkFest 2012, who's going>?
  • Frank Z
    edited January 2006
    Thanks again.
    What amps are you using? Can't say I've ever dealt with an amp that has its own volume control. Distortion is always a possibility, but it will depend on what type of amp and what it is rated for.
    As far as settings go, get an SPL meter and take a look at the following link....
    http://www.audiophilia.com/hardware/spl.htm
  • adam2434
    adam2434 Posts: 995
    edited January 2006
    Yep, a SPL meter is the way to make sure you're properly calibrated, especially if your receiver does not have an auto-calibration system.
    Several factors will determine the relative level of each calibrated speaker:
    Efficiency of the speaker
    Position/distance from SPL meter or calibration mic
    Room size and layout
    Don't worry whether the numbers are + or -, just be sure to get them at the same level on the SPL meter at your primary seating position.
    Regarding your amp question, running at the full volume setting will not necessarily cause more distortion. If the separate amps are more powerful than your receiver, you may need to calibrate them down a few notches from your other channels. For example, I run my amps at the full volume setting and my receiver's auto-calibration sets them to -7 to get them at the same level as the other channels. My receiver would power the center and the surround L/R and set them to something like -0.5, +1.5, +2.0, respectively.
    The only reason I would reduce the volume on the amps is if they were more noticeably noisy at the highest setting.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • adam2434
    adam2434 Posts: 995
    edited January 2006
    The volume you referred to may actually be for the input level. That's what it is on my amps.
  • brijenjas
    edited January 2006
    The amps are AudioSource AMP100. It is in fact a volume control,at least that's what it says over the knob.
    Thanks for the link.
  • SKsolutions
    SKsolutions Posts: 1,820
    edited January 2006
    I will add my two cents for what it's worth. When you deal with line level or low level signals (a mic for example), the rule of thumb for an audio engineer is: Set it to 10, and back it off a "smidge". This is to increase the signal to noise ratio in any signal before amplification. As dB is a metric to measure, you can use more absolute measurements that are linear (mV) Increasing the amplitude of a low level signal puts 'distance' between the top of the wave and noise threshold. That's about the best I can remember from days gone by.
    So, you should experiment. I have my settings as high as +8 on two speakers, and as low as -1 on another. I say set em high, but keep in mind that some preamps will clip, especially in the digital realm.
    Again, my two cents, and my "smidge" might be different than yours. My amp goes to eleven.
    Thanks to those that have welcomed me,
    SK
    -Ignorance is strength -
