Is it time for me to get a new receiver?
As most of you probably know by now, I'm using Harman Kardon AVR130 to power my new set of Polk Monitors. Power never was an issue before when i had MTX speakers with 94db sensitivity, but these new Polk speakers are only rated at 90db efficiency. When listening to music and stuff, i can notice small amounts of noise and distortion (traces of distortion seem to be present when the beat of a bass drum) present when listening to music above about -17 db (already very loud). Im beginning to worry that my little receiver is running out of juice for these speakers. My tone controls are neutral, and im using a Velodyne CHT-12 crossed over at 60Hz.
What should I do to eliminate this? Should I....
1) leave it alone... its barely noticeable anyway...
2) Get a beefy receiver (HK AVR635 or 7300)...
3) Get a cheaper HK receiver with preouts and get amps for the fronts?
Any tips are welcomed
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
3......- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I agree, #3. Once you hear the difference you will not look back. I own a Yamaha RX-V1500 and use a Rotel RB-1080 for the fronts.Michael
NORTH of 60° -
Switch the crossover on your Velodyne to 80hz.
Switch all of your speakers to "SMALL" on your H/K- and cross them over at 80hz. -
Thanks for all the tips. I actually used the tone controls to reduce bass from neutral (12 o'clock position), i move it to about 9 o'clock and got rid of any distortion probelms so I think i will leave it like that. I don't particularly like the sound crossed over at 80 Hz.... probably has to do with the fact that my room is small.
Anyway, what amps should i be looking at (please nothing TOO expensive)
Thanks again!KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
Outlaw.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
This one looks pretty nice:
http://www.outlawaudio.com/products/7125.html
Would an HK AVR235 or 240 be a good preamp for one of these?KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
