LSiC Questions
SuperDave
I got a new LSiC for Christmas and hooked it up. The sound is great(for Sportcenter). I noticed the driver on the right side is putting out more sound than the one on the left. I read the specs and determined this must be due to the sound source(mostly voices) and the crossover directing mid to one side and lows to the other? I have the speaker setting to Normal(which sends the lows to the LFE channels) per the manual. It seems this speaker could use Wide but that is not the recommendation. Am I correct thinking one driver will be putting out more sound than the other? Just want to make sure the thing is working right(sure sounds that way). Thanks for any input or suggestions. Merry Christmas!
SuperDave
Yamaha RX-V992
Panasonic DVD-A310
Sony XBR 27"
DVR
Polk LSi25 Fronts
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables
SuperDave
Yamaha RX-V992
Panasonic DVD-A310
Sony XBR 27"
DVR
Polk LSi25 Fronts
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables
SuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables
Denon DVD-1920
Mitsubishi 40" LCD
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables
Post edited by SuperDave on
Correct
It is called a Cascaded Tapered Array (if you want more info, this can be also found in the LSiC page on the Polk site.)
Merry Christmas!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
SuperDave, play around with the settings on your reciever.. sometimes the recommended setting isn't always right for your room and set up.. so try the small, then the large setting any any other settings your receiver has.. and find the sound that best works for your ears.
PolkFest 2012, who's going>?
Here are a couple of threads relating to this topic:
http://www.polkaudio.com/forums/showthread.php?t=23500&highlight=cascade
http://www.polkaudio.com/forums/showthread.php?t=22416&highlight=cascade
Enjoy the new center channel.
ZachTschüss
Zach -
Thanks for the replies, I need to hone my search capabilities, next up, amps and more LSi for the rear...as soon as funds replenish...
SuperDave
Yamaha RX-V992
Panasonic DVD-A310
Sony XBR 27"
DVR
Polk LSi25 Fronts
Polk LSiC Center
Infinity RS1 Rears
Monster THX CablesSuperDave
Denon DVD-1920
Mitsubishi 40" LCD
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables
