Anti Vibration Insulation Feet - Cheap!
mlhm5
Vulcanized Rubber already made 3"x1" $1 each, stackable, gluable, drillable, withstands earthquakes, made in CZ.
The Hockey Puck
The Hockey Puck
Are those really necessary? Do they make any difference at all?
I think I will stick to my big sheet of foam... which has performed admireably!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Do hockey pucks have anti-vibration properties?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Yeah, but if anyone ever comes over to Sids, and wants a pickup game of street hockey, that piece of foam just won't cut it!HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I don't know the resonant frequency of the pucks but they look better than blocks of wood stuck everywhere. IMOHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis Gardner wrote:Yeah, but if anyone ever comes over to Sids, and wants a pickup game of street hockey, that piece of foam just won't cut it!
Neither would those rubber pucks.... you pretty much need those roller-ball pucks for street hockey, unless it's icey out. Or you could do as we did in high school gym class on rainy days (and the entire winter), which was use a rubber ball. I'll be damned if that thing didn't leave a MARK when it smacked you in the shin!
And hey, that could be used as an isolation device as well... as long as you _don't_ get many earthquakes...Ludicrous gibs! -
Vr3MxStyler2k3 wrote:I think I will stick to my big sheet of foam... which has performed admireably!
I cut up a yoga mat and these work better. It's catching on so don't be suprised if the price of hockey pucks goes up and BTW, you don't have to keep them in the freezer.
Seriously, they work. Got the idea from a high end shop that worked on the Accuphase 100 pictured. -
Yeah, the puck tweak has been around a LONG time.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Taste good, but they're kinda hard to chew (and digest)...More later,
Tour...
Vox Copuli
