+ & - speaker pole ??
coronaguy
How can I tell if I have the speaker wires connected to the proper pole on the speaker? Wire snakes thru the house and I can't tell for sure if the wire is marked properly. Can I use an electrical tester somehow?
Post edited by coronaguy on
Usually the wire itself has some kind of marking to indicate the negative side.
Any kind of phase check (like on THX DVDs) would pretty much tell you right off.If you will it, dude, it is no dream. -
There may be ridges formed into one side of the speaker wire, writing may be on one side of the speaker wire, or it could be a different color. Just make sure that the side with writing (or ridges or color) is plugged into the pos. (or neg) side on both your AVR and speaker.
Yes, you can do a continuity test, but you would have to be able to connect to both ends, and I am guessing that would be difficult at best....
As stated above look for special markings, or small ridges on the insulator on one side. If both conductors are identical, use an ohm meter to find continuity, then mark with tape for future reference...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks for the response. I have determined that they are wired properly
That is good to hear. I was basically just going to say wire one side to a 9V battery and then use a digital volt meter from the Rat Shack to determine the +/- sides... Only costs about $10
