Internal Vibrations
Early B.
Early B. Posts: 7,900
How do you determine if your sub is not properly braced or could benefit from improved bracing?
Is there a way to measure or determine the amount of bracing needed in a sub?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • PolkThug
    PolkThug Posts: 7,532
    edited December 2005
    See if it sounds better with a heavy weight on it.
    Measure decay.
  • tryrrthg
    tryrrthg Posts: 1,896
    There is some sort of test equipment out there that will measure the movement of cabinet walls, but I don't remember off hand what it is called. I'm sure it's not that cheap.
    According to all the DIY gurus this is the proper way to build and brace a sub with a high excursion 15" driver.
    Some of it is probalby overkill for most real world applications but it all depends on how crazy you want to get. If you don't want to mess with bracing at all build a sonosub.
  • Early B.
    tryrrthg -- that link you provided is defintely overkill for bracing. It would be cost prohibitive, take a lot more time to build, and the sub would be very, very heavy. Not sure how much SQ difference it would make anyways.
  • tryrrthg
    You're probably right, but that's the beauty of DIY, YOU get to decide if it's overkill or not, not some executive trying to cut corners/costs.
    Personally I don't think it's that much overkill, large panels in a sub like that (some are around 3 feet in length) will certainly vibrate like crazy, causing nasty resonances. If I had a dedicated theater room I'd certainly go to that degree of "overkill" but a box that big just won't fly in the REAL world.
  • MacLeod
    MacLeod Posts: 14,358
    Im assuming youre going to build your own box? How many watts are you going to be pushing?
    Im running about 400 to my sub and built the box out of 1/2" birch plywood and have no issues with flexing.
    Unless youre going to be running near 1000 watts, I would worry too much about bracing. Just make sure the enclosure is well sealed and built properly and it should be rigid enough.
    VR3 Posts: 29,434
    I believe in absolute overkill..
    I kind of feel I didnt put enough bracing in my main channel rebuilds I am working on... that 10" or so of empty space is bugging me... I may have to add a few strips... lol...
    But 230" of bracing...is cool!
    One of the EASIEST ways to tell if your box is braced, that takes like 1 second is knock on it...
    If your box dosnt go... THUD.. something is wrong or it isnt braced enough. There should be barely any resonance...
    Why build something thats supposed to be better than the competition (for the same money) and not go all the way. Yall regret it in the end.
    I used strips and plywood for a few reasons BTW-
    It dosnt take up as much air volume... and plywood is stronger and lighter weight... FWIW
  • goingganzo
    goingganzo Posts: 2,793
    i have some isued with vibration. the whole wall with i installed my ib shakes. befor i re enforced it with a 2x6 it would move 1/8 of an inch. i will be adding more braces later when i get time now it just shakes the entire house.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Depends on the design somewhat. Ported boxes such as the linked one don't need as much since pressures are lower. You need enough to keep long spans from flexing and break up the panel vibes. Sealed boxes need alot more attention to panel flex though.
    I have always liked the cross type bracing on the Adire designs.
