Using TV speakers as center channel
tsv
tsv Posts: 13
edited December 2005 in Speakers
Has anyone tried to use the TV speakers as center channel (center speaker out from receiver to TV audio IN jacks)?
Post edited by tsv on
  • Ferres
    Ferres Posts: 310
    Depending on the tv, but it will most likely suck. :P
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • Skynut
    Skynut Posts: 2,967
    I tried using the t.v.'s sound as a center but it was not all that great.
    Now my set can not play the soundtrack at all when I watch movies.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Willow
    Willow Posts: 11,220
    I think this is the worst idea ever. I'd rather go phantom !
  • aaharvel
    aaharvel Posts: 4,489
    If you want a LO-FI spread between the 800hz to 5 khz range then by all means use the TV speaker as your center channel.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Schris22
    Schris22 Posts: 983
    I would go phantom
    Agreed with Willow.
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • Larry Chanin
    Larry Chanin Posts: 601
    Hi,
    As Ferres said it will depend on your TV.
    If you have a big, expensive TV with decent internal speakers, have your main speakers widely spaced, and you watch it with an audience, then it may be of some benefit to try experimenting. However, if you are a solitary listener, sitting on-axis, watching a small TV with crappy internal speakers, then a phantom center would probably sound better.
    In my last home theater I had an old rear projection HDTV, and it had a pair of internal speakers that didn't sound toooo bad. At first I wanted to try to experiment with using them as a center. However, in order to use my external sound system with the HDTV, the TV's menu system automatically turned off the internal speakers. It was one way or the other, but not both. I ended up getting an CS400i center channel, which of course was waaay better than the internal speakers and I never looked back. In this configuration my main speakers were about 13 feet apart, and I had two row of seating that was widely spaced. A phantom center would have been totally unsatisfactory to all members of the audience except the one person seated on-axis in the front.
    Larry
  • janmike
    janmike Posts: 6,146
    I have a basic CSi5 and there is no comparison to any TV speaker that I have heard. Go for the centre.
    Michael ;)
    NORTH of 60°
  • puunda
    puunda Posts: 127
    I don't think a centre is needed for a home setup. As long as you sit in the middle of the 2 speakers (you should be anyway), why would you need a centre? I thought this was the whole point when everything moved from mono to stereo was that with 2 speakers, you can 'create sound' which sounds like it's coming from the centre. I've always thought the centre chan was inveted for the cinema where you don't always sit in the middle. In fact most of the audience don't sit in the middle. Set your receiver to NO centre, and the information should be routed to the 2 mains, and you shouldn't noticed a difference (as long as you're sitting in the middle).
  • Larry Chanin
    Hi,
    I think it really depends on what you mean by a "home setup". Today the term "Home Theater" has become widely used in the states. In some cases this may actually be a dedicated room in the home for the sole purpose of having family and friends over to enjoy watching movies together. (Take a look at my home theater to see what I mean.) Often it's a multi-purpose room which serves other uses in addition to having groups of people over to watch movies.
    The important thing to note is that this term doesn't refer to a solitary listening experience with a central, on-axis "sweet spot". As I alluded to earlier, we are also not talking about a small TV's only a few inches wide with main speakers on either side. What we are talking about when we say "Home Theater" is big screens, with audiences. If you have an audience phantom centers are not going to accommodate the listening experience for the majority of the people.
    While it's true that center channels were originally created for commercial theaters, that's no longer where most of them reside. ;)
    Larry
