Polk Monitor 4.5
mlhm5
Anyone know anything about this speaker? Tweeter type, quality, value? Could not find anything on Polk, however seller says they are definately Monitor 4.5.
2-way speakers with a approx. 51/2" woofer and 1" tweeter.
Dimensions: H. 17" W. 9" D. 91/2"
Thanks in advance for your help.
Post edited by mlhm5 on
The monitor 4.5 used an RD0202-1 tweeter and the MW6502 woofer (6.5"). Can't tell you a whole lot more than that.Ludicrous gibs!
Here's two completed ebay auctions, courtesy of www.polksda.com
http://polksda.com/ebay/Monitor4_5826621910.pdf
http://polksda.com/ebay/5740517471_Monitor4.5.pdfLudicrous gibs! -
Notch below the Monitor 5's and above the Mon 4's. Ported not PR'd. They sound OK for what they are.
I've got files on about 10 auctions. $60 to $80 is the normal range.More later,
Tour...
Vox Copuli
