LSiC bi-wire / bi-amp question about cables.
LSiC - What's the more important set of bind posts, or give opinion on if bi-amp'd what cabling requirements should be fulfilled for the different bind posts. Like if I've witnessed one cable to be more "open" sounding and I wanted to continue that sound improvement, would it be best placed on top or bottom?
For example, let's say you are going to bi-wire or bi-amp, but you have two different types of speaker cable. Both are same gauge, but one is "Original Monster" and the other is "Acoustic Research Master Series".
I seem to prefer the AR's much better (and I bet most would), but should I put that one on the top or bottom posts?
Or is this really just a, must listen and diagnose thing. Or maybe you shouldn't ever really do this with different cables.
Post edited by jrlouie on
You'll have to listen for yourself. I voted for AR. Don't give your money to Mon$ter.
