PDA's/Pocket PC's
okiepolkie
Not sure exactly where this belongs, so here it is.
I'm needing a PDA/PC of some type, however, I don't know exactly what to get. Haven't ever shopped for one, so I don't really even know what is available.
It is primarily for my home theater install business, so I need a little more than a piece of paper for everything(seem to always misplace paper, not electronics).
Here are my needs:
1)Keep datebook(I know they all do this)
2)Store customer information information: model numbers, calibration settings for audio/video......
3)If possible, I would like to download remote control codes(Harmony), so I can update cutomer remotes without hauling my laptop around. I guess this would require a regular USB port from the PDA
4) I don't need a phone
That is about it.
If anyone can help, it would be appreciated.
Zach
Here are my needs:
That is about it.
Zach
Tschüss
Zach
Zach
Post edited by okiepolkie on
Is the only way to get the codes onto the Harmony remotes though a usb cable?
You can do infrared learning, but that would take up more time than it would be worth.Tschüss
Zach -
you should checkout an HP iPaq - palm sized computer, no phone. Operates with Windows Mobile - just like a laptop but palm sized. Don't know what it's RF capabilities are though....VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
#3 might be your downfall...
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments.
