RT600 or M60 for front?
I have a choice of going with RT600 or M60's (T90EB actually) for fronts then building around those.
For mainly HT use, which of these would make better fronts? I have a CSI30 for center. Ill deal with rears when I decide on fronts, or perhaps, just move whichever I dont use for fronts to rear since I don't care to match at this point (room too unacoustily sound to matter).
Thanks for any suggestions.
Post edited by bmisthhou on
it may be easier to find other speakers to match the Monitors...
I'd personally chose the RT600 over the Monitors for sound though, just because I personally like them better... -
I beleive I have access to some RT25's for surrounds with the RT600's or I could go buy some bookshelfs that match the M60. Either way I'm not sure which set would produce the best sound?
The RT600's will have the better sound. You can always find speakers to match on ebay.
Zach
edit-sorry, didn't see the csi30. I would go with the RTi70's or RTi8's if I had to floorstanding. Or, sell the 30 and get a CS400 to match it.Tschüss
Zach -
Help with why only the 600 or M60 choice? Neither are great matches for the CSi30. You are better off with fronts with the same silk dome as the center. If you haven't purchased yet, look harder since better matches are out there.
I have used mismatched center/mains with decent sound, but there are subtle differences.
Just my .02HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
