The tape that Polk uses to attach side panels?
VR3
VR3 Posts: 29,428
edited November 2005 in DIY, Mods & Tweaks
I am curious what the double sided tape Polk uses is... (a name?) - and aside from setting the tape on and setting the piece right... is there anything else required to use it...
I am contemplating using this to mount my side panels..
Post edited by VR3 on
  • beardog03
    beardog03 Posts: 5,550
    the answer is in the wall vault behind the pic of Matt at HQ..!!
    you didn`t hear that from me though....oh ya, this is a public forum..
    nevermind...don`t know...sorry bro can`t help ya...
    Noel
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • ledhed
    ledhed Posts: 1,088
    You could try the tape used to put golf grips on the shaft. you wet one side and boy is it stuck! I'm not sure how much weight it could hold though.
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Comes in several compositions from 3M - look here
    VR3 Posts: 29,428
    Looks like it would be cheaper to just use wood glue... lol
    Thanks Blue... I aprpeciate it!
  • BlueMDPicker
    You're welcome.
    Yep, in a one off build like yours, glue is the most economical. In a production run setting, they can stick 'em and pack 'em with no worries about seepage.
  • jrlouie
    jrlouie Posts: 462
    Here's an up-close shot at the tape. I removed the panels on my Lsi15's because they faded. I actually haven't put the new ones on yet because I love'em naked :D
    http://www.polkaudio.com/forums/showthread.php?t=27613
    Be sure to get the black tape so it blends better.
  • unc2701
    unc2701 Posts: 3,587
    Search for "3m VHB" on ebay... lotsa auctions for under $10.
    Backburner:Krell KAV-300i
