The tape that Polk uses to attach side panels?
VR3
I am curious what the double sided tape Polk uses is... (a name?) - and aside from setting the tape on and setting the piece right... is there anything else required to use it...
I am contemplating using this to mount my side panels..
Post edited by VR3 on
the answer is in the wall vault behind the pic of Matt at HQ..!!
you didn`t hear that from me though....oh ya, this is a public forum..
nevermind...don`t know...sorry bro can`t help ya...
NoelCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
You could try the tape used to put golf grips on the shaft. you wet one side and boy is it stuck! I'm not sure how much weight it could hold though.God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
Comes in several compositions from 3M - look here
Looks like it would be cheaper to just use wood glue... lol
Thanks Blue... I aprpeciate it!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You're welcome.
Yep, in a one off build like yours, glue is the most economical. In a production run setting, they can stick 'em and pack 'em with no worries about seepage. -
Here's an up-close shot at the tape. I removed the panels on my Lsi15's because they faded. I actually haven't put the new ones on yet because I love'em naked
http://www.polkaudio.com/forums/showthread.php?t=27613
Be sure to get the black tape so it blends better. -
Search for "3m VHB" on ebay... lotsa auctions for under $10.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i
