One more question for Ken
organ
Hi Ken, I posted my message about a week ago concerning the CS400i I got from Future Shop which had a blown driver. You gave me the phone number of the Canadian distributor but I haven't called them yet to get the replacement driver because my credit card is maxed out at the moment. Do you know how much the replacement driver is in CDN $ and the serial number for the driver(left woofer) or is the speaker still under warranty?(got it in Aug with the blown driver)
Thanx
Maurice
Thanx
Maurice
Post edited by organ on
Hello,
From everything you've indicated I believe it would be covered under the warranty. You may be asked to send in the non-working driver, but that would be the only expense.
Regards, Ken
