Suggestions for Rear Surrounds
swisheri
swisheri Posts: 12
edited July 2002 in Speakers
OK. I am ready to purchase rears to complete (almost-still need a sub...i think) my surround sound system. I am planning on mounting on wall with some sort of mounting bracket. I have
Polk M10s B, newly purchased csi40 which matches up pretty nicely with my old school polks. I would like a bookshelf model. Any suggestions? Also are center rear channels worth it?
Thanks,
Ian :confused:
old school polk
Post edited by swisheri on
  • dlew308
    dlew308 Posts: 530
    edited July 2002
    what's your receiver?
  • swisheri
    swisheri Posts: 12
    edited July 2002
    Onkyo TX-DS 797...It was an upgrade from Onkyo TX-80. I am hearing sounds from my M10s that I haven't heard in a long time. Pretty incredible.
    I am eventually going to bring my 10s in the basement (when finished) and replace the fronts.
    old school polk
  • mhw58
    mhw58 Posts: 359
    edited July 2002
    I have POLK SDA2's with the SL2000 tweeters. I've been trying
    to decide whether to buy a CS400, 400i or 40i center. Do
    your monitor B's have the SL2000 tweeters? Do you think the
    40 i would match as good as the 400i?
    Thanks, Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • swisheri
    swisheri Posts: 12
    edited July 2002
    I don't really know what kind of tweeters I have.
    I believe they are SL2000. I can't really answer your second question because I haven't heard the others to compare. When i was ready to buy the center-I couldn't find the 400i. I can tell you I am very happy with the 40i. I think it sounds great. I bought it at http://www.acousticsounddesign.com for $299.
    old school polk
  • mhw58
    mhw58 Posts: 359
    edited July 2002
    The SL2000 tweeters are black and the sl1000 tweeters
    are a brushed aluminum color. Most likely, your Monitor
    10's have one of them.
    Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • sgtnate79
    sgtnate79 Posts: 12
    edited July 2002
    Im still trying to find someone who can tell me about the new R20. I am just looking for some positive feedback before I get them for my surrounds. Not trying to steel your fire swisheri.
    Nate
    Onkyo TX DS-595
    Front: R50's
    Center:N/A (CSI 20 Soon)
    Surround:N/A (R20's Soon)
    Sub:N/A (Not Sure)
    X-Box
    Panasonic 20" (Sony 32" HDTV Soon!)
    Sanyo DVD
  • swisheri
    swisheri Posts: 12
    edited July 2002
    My tweeters are black so I guess they are the SL2000. Anyway, I'm thinking RT25i for the rears. And I can mount them on the wall. Any thoughts? They have received pretty good reviews...
    old school polk
  • Ron-P
    Ron-P Posts: 8,516
    edited July 2002
    I use the RT25i's as my rear surrounds. Outstanding little speaker. I build my own surround mounts from 3/4" galvianized pipe from Home Depot. They work great and were very inexpensive.
    Here's a pic.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • swisheri
    swisheri Posts: 12
    edited July 2002
    Ron,
    Your home theatre room looks awesome! Thanks for the pic. Did you screw into the speaker cabinet to mount the speaker to the bottom plate?
    Ian
    old school polk
  • Ron-P
    Ron-P Posts: 8,516
    edited July 2002
    Thanks Ian. Yes I did, but I did not screw all the way throuh and breech the inside of the box. I did use earthquake putty at first, which held really well, but I did not feel comfortable with that and seats directly under the speaker so I used screws.
    Peace Out~:D
    If...
  • nascarmann
    nascarmann Posts: 1,464
    edited July 2002
    Wrong!
    Oh, the bottle has been to me, my closes friend, my worse enemy!
  • swisheri
    swisheri Posts: 12
    edited July 2002
    Thanks for the input nascarman. What color are the SL2000 tweeters?
    old school polk
  • nascarmann
    edited July 2002
    This is a SL2000 tweeter.....not a good one though
  • mhw58
    mhw58 Posts: 359
    edited July 2002
    My SDA2's have that same looking tweeter, only they are
    black. Polk sent me some literature with the SL2000
    looking like that and they are also black. What's the story?
    Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • mhw58
    mhw58 Posts: 359
    edited July 2002
    I should clarify, the tweeter itself is the clear dome but
    the metal housing is what is black.
    Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • swisheri
    swisheri Posts: 12
    edited July 2002
    Thanks for the pic nascarmann. My tweeters on my M10's look exactly like your pic. Is there a sonic advantage of the SL2000 versus the SL1000?
    Thanks, Ron for the mounting info. Seperate thought-- I am not sure that I need a sub with my M10's up front.
    old school polk
  • mhw58
    mhw58 Posts: 359
    edited July 2002
    I've read and been told that the SL2000 tweeters were a
    lot better than the 1000's. I'd be interested in knowing
    more about the differences also, and why the 2000's
    are better.
    Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
