Volume control
mknutt
I am going to run some outdoor speakers to my patio. I was wondering if anyone has a good recommendation on an in-wall volume control they have used. I have looked at this one from Crutchfield, but it seems a bit steep.
Niles volume control
Thanks.
Thanks.
Post edited by mknutt on
I never used one, but try these:
http://www.partsexpress.com/webpage.cfm?&Webpage_ID=3&DID=7&CAT_ID=43&ObjectGroup_ID=275&SO=2Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Speakercraft makes really good quality inwall gear. Just Google "speakercraft volume controls". This will pull up a number of listings. If you are looking for a basic indoor control they can be had as cheap as $18. I think the weather proof outdoor controls start around $60.
Hope this helps.
LaterHT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
Yeah that niles in wall seems a little high. Heck you can get an RF remote with a IR repeater/converter for almost that much...
