Ripping music to computer
michael_w
Wasn't quite sure where to put this one but anyways... I just reformatted my computer and I'd like to stick most of my music back on it eventually. My question was which format would provide the best sound quality without making the files massive. I realize you can do things like use exact audio copy and create near lossless files but at ~500 mb a cd and with a collection of about 200 cd's I don't think that'll work well. I only have 160 gb hard drive and I'd like to keep some space for tv recordings and dvd's. Before the reformat I just did mp3's at 320 kb/s and they weren't too bad but I was just curious if there was a better format at about the same file size. I'll be using iTunes to play back the music.
Thanks,
Michael
Thanks,
Michael
Post edited by michael_w on
well, that depends on you tastes in codecs. I use MP3's at 320 like you did but theres more to it then that. The software you use will make a big diferance in the quality of the rip more so then the format. I personaly stay away from WMA and the likes. *.oggs are very nice. But its not all that comon so I dont recomend you rip to it. Also whats your sound card? If you are lucky enought to have a Creative X-fi it uses hardware mp3 encoding so its far better then any software ripers.
If I were you I'd try WinLame http://winlame.sourceforge.net/ I'm shure otheres here will coment on the Encoder. Also it does ogg's
What's the scoop on .oggs? My media player will play them, but how would I rip to a .ogg file? And what's the difference in a software and hardwoare encoder?
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
*.ogg is kinda rare for now, but its a profesional format. It is said that it maintains a higher fedelity. And I can vouch for that. MP3's sound flater to me kinda dull incomparison. This linky http://www.vorbis.com/faq/ will explain all about ogg. Hope it helps!
You can rip to ogg's by using suporting encoders like the one I posted above.
Now to the hard question. Creatives X-fi uses some new algarithums (soo cant spell) that pruduses a clairity like I have never herd before! It doesnt use losse software codecs and the like but instead its all done directly on the chip. The details arnt really known yet since creative isnt forthcoming on such things. Never the less its truly amazing what that sound card can do. -
Thanks for the suggestion. I think I'll just stick with a more common format so that I leave more options open for messing with the files (put on my pocket pc, import into other programs). This isn't for critical listening or anything, but more of a massive library on shuffle for background / doing homework music
I'll give the winLame a shot and see how that goes.
Thanks,
Michael -
good choice
If you have any problems with the program feal free to PM me with questions or posty in thready...
Cool. I might have to start ripping in .ogg format just to try it out. How much does that card sell for? Is it also a great sound card for playback?
Thanks for the information.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
After reading that link on .ogg, I think I'm sold, lol.
Is there a progam that will rip into .ogg format that you would recommend over the winLame that you linked to?
Thanks!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Is currently the best. There are 4 product lines and I'll give you a breife run threw.
X-Fi Xtream music = Base card, doesn't have the onboard 64 megs of ram used for gaming (worthless to date anyway) $100 - $125
X-Fi Plat. = Includes a breakout box for the front of your PC with optical in and out for an added $70 bucks!
X-Fi Fatality= Includes 64 megs of ram and a light on the card with the fatality symbol = $250 and not worth it
X-Fi (cant remember) = Focused on home theater users, very expensive! Only difference is it has an external decoder and 7.1 output processor on the decoder versions the onboard card.
There curently the best simply due to there MASSIVE on board proc.
http://www.creative.com/products/welcome.asp?category=1&subcategory=208&
heres where we PC geeks drule "51M transistor CPU (OMG) APU/10,000MIPS" In lamence terms thats one hell of an audio prosesor! with a s/n ratio of 109dB
So out of that line up you'd say the X-Fi Xtream music would probably be the best, eh? Interesting.
I read about it on compusa's website and it never said a thing about .ogg.
http://www.compusa.com/products/product_info.asp?product_code=333984&pfp=BROWSE
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I see that there are a few different versions of WinLame availabel. Which one should I try out?
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Its the best bang for the buck out of the whole line up. But it wont rip to oggs by defult. You will need to use the Lame codec first. once its instaled into your system it will then reconize it as a selectable format
Hmm. So it still uses software.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
So I just installed WinLame and I'm playing around with it...does it just encode files? It won't actually rip from a CD? So I should rip in .wav or something and then encode it in .ogg?
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I rip cds to my pc all the time using Windows Media. Just put the disc in & tell it to rip & specify where you want it to go. Then I burn the tracks onto another cd. I have a blast doing it, and have a nice collection of discs at work to listen to rather than the radio.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
^^ That's the latest way I've been doing it. Before that I used EAC to rip them in .wav format. However, that took up a bunch of space and made it difficult to send them to folks through AIM.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
ohhh.. look at that. Winlame used to suport riping in its earlyer sourcsforge days. Thats kinda **** now. Here you go CDex http://sourceforge.net/project/showfiles.php?group_id=567&package_id=584&release_id=183719 It also uses the Lame encoder. and is very popular. but there main page is down.Google it later on, the above link is a direct download. When I try to view the home page I getaudiobliss wrote:So I just installed WinLame and I'm playing around with it...does it just encode files? It won't actually rip from a CD? So I should rip in .wav or something and then encode it in .ogg?
"MySQL Has Reported Errors
Error Number: 2003
Error Information:
Can't connect to MySQL server on 'mysql.sourceforge.net' (111)
TwkDDb Version 0.3a " -
I just downloaded and installed that version. When I double clicked the icon to start it, an error popped up and said:
Failed to load the wnaspi32.dll driver!
Use the "Native NT SCSI library" driver option instead?
What's that mean?
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
uhh... ummm... errr...
*runs from thread!
hahahah!
I'm a-gonna click yes and see what happens.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
That one was way beyond me bro.
Well, I ripped my new Bob Seger CD in .ogg format! And foobar2000 is playing it just fine! One of the songs is 5:33 and takes up 17.9mb.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
hows the fidelity?
Well so far I'm just using it as background music and through my receiver and Scott speakers, so I'm definitely not listening critically. But I'll give it a more critical listen tomorrow afternoon.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
EAC will rip to .mp3, thats how i rip my cds...2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
Oh, it will? I never knew that. I thought it required another encoder, so I also downloaded lame to use that to convert the .wav files to mp3.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Interesting... I might just try eac to rip mp3's and compare those with ones of the same file size ripped straight from iTunes. In the meantime I'll be waiting for audiobliss to fiddle and work out the bugs
Now, the thing is that EAC doesn't rip them to mp3. It rips them to .wav files, which is what's on the CD. I used Lame, I think, to convert them to mp3's after I ripped them. However, I quickly stopped converting them and just using the .wav files as I have a 200gb HD and didn't need the space.
So far I'm pleased with the WinLame Josh-s linked to in the end. You put in your email address for the CDDB querry, and all you do is select what format and quality level you want the music in, pop in the CD, and it goes to work. I have it set to encode in 'ogg vorbis' at a quality level of 10 which is the best (about 400kbps). It's a little slower than using WMP to rip to WMA's, but it's not too slow.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
HD's are cheap so I would just add another to your computer. 300-400GB drive will go a long way. Other options are to add an external drive (external USB case with IDE-adapter will be cheaper than already assembled drives) or a file server, in case adding an internal drive is not an option.
I might just do that... So far the 160 gig western digital I have now has done just fine but now that I have a tv tuner card I'll be recording a lot of tv. Add that to my music and the space I need for making copies of dvds and my extra space might dissapear pretty quickly. I think I'll have to just deal with it for now and add another later because my computer desperatly needs another 512mb of ram and a video card first. It's a good idea for the christmas list though
i have been using cdex when ripping to mp3 for a while now, i am pretty sure that it does ogg as well. it is very simple to use and i have had no problems with it. i was previously using EAC to tediously do the ripping and then something else for the encoding but honestly the only time i ever heard a difference was when the cd skipped in which case i would just re-do the song.
