Polyswitches
djf
djf Posts: 120
edited November 2005 in Vintage Speakers
OK, two questions.
First, I called Ken and ordered the polyswitches, which came today.
But they are orange, not blue. And the schematic doesnt match at all the crossover I have, my crossover comes out the front, secured by 8 hex screws, it looks exactly like the crossover in DarqueKnights crossover rebuild thread.
I have always called these speakers "SDA-SRS's". Since there seems to be confusion, what should I call them?
Now, secondly, is it safe to use the orange polyswitches instead of the blue ones? Or will I blow them out the first time I put power to them? Anybody know?
Thanks!!
Post edited by djf on
  • schwarcw
    schwarcw Posts: 7,358
    Do you have a pic of them?
    Carl
    Carl
  • djf
    djf Posts: 120
    Speakers or switches?
  • djf
    djf Posts: 120
    These are the original SRS's, before the 1.2's
    http://www.polksda.com/sdasrs.shtml
  • madmax
    madmax Posts: 12,434
    I don't see any confusion, that is what they are called. ???
    madmax
    Vinyl, the final frontier...
  • schwarcw
    Nice! Are these 1.2TL's? Check out the labels on the back. It should read 1.2 or 1.2TL. From what I read the crossovers on the 1.2 TL's are slightly different from the 1.2's.
    Carl
  • djf
    djf Posts: 120
    Nope. Neither.
    It says:
    Polk Audio
    The speaker Specialists
    SDA Signature Reference System
    Left channel
    The drivers are (per spkr) 4 SL2000's, and 8 MW 6503's.
    And of course the interconnect cable.
    MF date Nov 18, 1985
  • djf
    djf Posts: 120
    OK. Rather than putting the orange polyswitches in, I bypassed the ones there. I know, I know, don't play it too loud!
    Surprisingly, improved definition. Brighter sound, and certainly tighter bass. I know, doesn't make sense.
    Currently: Money's too tight to Mention, Simply Red
  • BobMcG
    BobMcG Posts: 1,585
    They look different because they are different switches with a different value. You know, as in upgraded/improved switches over the stock ones.
    I know you already got a bit impatient and bypassed but you asked so.....
    1) Yes, they are safe.
    2) No, you will not blow them out.
    3) Yes, thus this post.
  • djf
    djf Posts: 120
    They sound so freakin good with them bypassed, unless I get real ambitious, I might just leave them that way.
    Are the RDO tweeters that much better it justifies another 400 bux into these puppies?
    here's a blurry shot I took last fall, before I bi-amped them.
    web3.foxinternet.com/djf/mpolk.jpg
    F1nut Posts: 51,751
    Brighter sound? That's not something I would want from my speakers. Besides, those SL2000's are too effing bright already!
  • djf
    djf Posts: 120
    Well, I like them that way! Hearing things I never heard before... I also am basically using a ten band graphic equalizer as a pre-amp, so I have alot of control.
    F1nut Posts: 51,751
    To each their own, but no self respecting audiophool uses a graphic equalizer for any reason. Stick around, you have much to learn.
  • BobMcG
    BobMcG Posts: 1,585
    With your signal running through a signal distorter err, controler like that a little'ol poly switch in the loop would certainly be the least of your worries. ;)
    To each their own.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    The eq is so that he can add a 10 db bump in that ever so important 13khz spot those SL-2000 tweets are weak in. He likes it hot!!! :D
  • BobMcG
    BobMcG Posts: 1,585
    Jes,
    I guess great minds think alike. :p Must have been typing at the same time. :)
    F1nut Posts: 51,751
    Yeah Bob......great minds and all that, but I like your choice of words better than mine. :)
  • beardog03
    beardog03 Posts: 5,550
    those look like the ones that were in San Jose..
    did ya get a good deal..?
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • djf
    djf Posts: 120
    No, I am the original owner, purchased at some high end audio store in north Seattle summer, 86. IIRC, 33 hundred and change, and I paid a friend of mine 100 bucks to help me move them.
