2 12" Speaker split box
i was actually considering this amp for a while
and you could use a 200WRMS x 2 Ch. @ 4 Ohms amp for 2 mm2124s, but you won't be getting their full potential...It's not good, very fundamentally simply not good. - geolemon
i thought he was using sonys...Picking ones nose signifies a strong sense of self discovery
System in the works:
PP 6V6 with 12ax7 pre ~ 20 watts
15" Jensen MOD 8ohm ~ 97db SPL
DiMarzio HS3 and/or Tone Zone S -
neomagus00 wrote:i was actually considering this amp for a while
..........yea thats a good one, theres no F&c%n way!!! is that like the most bestest aps of all time or what???? HFS!!KDC-MP5028- Kenwood deck
Phoenix Gold speaker wire
Alpine 6-1/2" Type-R Coaxial 2-Way Speakers- SPR17LP-, in side doors
Alpine 5x7" Type R speakers -SPR-574A-, in the back.
2 Alpine type R subwoofers in custom box
1000 watt Alpine -MRD-M1005- AMP
-Price invested- Over 1500$
Not the absolute best, but it works like a champ, you can hear it from like 2 or 3 blocks away from your stand point. -
Quick question, if i have a MONO amp that puts out 310 watts RMS, can i hook up two subs up to that one channel, and have them bolth be powered by 310 watts each sub?
And, with those two sony subs, should i hook up a terminal for each of the subs? or should i hook bolth subs to the same terminal?KDC-MP5028- Kenwood deck
It depends.
Say you have an amp that makes 310 watts at 2 ohms. That means it will put out 310 watts at 2 ohms total regardless how many subs you have hooked up. 1 sub would get 310, 2 subs would get 155, 4 subs would get 77.5 and so on.
If youre subs are single 4 ohm voice coil subs and you wire them both to you mono amp youll be getting 155 to each sub.polkaudio sound quality competitor since 2005
that looks pretty good, wanna make one for me? lol
I just got this amp for free and it is in fair condition, but i cant find anything on it on the net........ it is a,
-"Mobile Authority" "Percision Audio" Amp.
-It reads 150X150 watts, i have no clue if that RMS or not.
-It is bridge-able
-0.05THD
-Mosfet
-"Class A curcuit"
Model #THA-1500
DISCRIPTION:
It is white, with a big blue THUMP logo on it and has a red "lightning bolt" going across it.(i dont know what it is, me and having weird **** with lightning bolts on it???)KDC-MP5028- Kenwood deck
i fear it...It's not good, very fundamentally simply not good. - geolemon
I took some pics of it.....,
An overall look at it...
heres the LOGO that i was talking about
Alright, i dont want to sound stupid here, but i have no clue where to start hooking this bad boy up?? What dose, "bat" stand for? what about REM? and gnd? in that for-ground? i feel like a complete dumb **** here!!!!
I assume BRIDGED, i would hook up the negative of the amp to the neg of the sub and the same for the positive right? just like it shows yes?
Heres the "stats" i guess you would call it, is that 150X150 RMS? or can you guys tell from that?
Sorry for all of the stupid bull ****, i konw this is a 6 or 7+ year old amp, i just want to see what the difference is between this and newer stuff, thanks.KDC-MP5028- Kenwood deck
it's likely to run very hot, if it's a true class-A amp... looks okay, though...
BATT+ is the +12V line, GND is ground to the chassis, REM+ is the remote turn-on lead from the HU, and to bridge it you would follow the little markings like you said...
from what's listed on the amp, btw, it's 2 x 150 WRMS, not 150 x 150... that'd be 150 channels at 150 watts apiece
neomagus00 wrote:it's likely to run very hot, if it's a true class-A amp... looks okay, though...
do you think it is possable for an amature like me to hook it up?KDC-MP5028- Kenwood deck
Still learning wrote:
oops my badneomagus00 wrote:it's likely to run very hot, if it's a true class-A amp... looks okay, though...
fyi, the format is [ quote = name ] blah [ /quote ] without the spaces...
and yes, everyone has to start somewhere... preferably, find someone who has done it before to help you... or, be like me, and be prepared to spend significant time making sure you got it all right before you turn it on...It's not good, very fundamentally simply not good. - geolemon
yea, my buddy shane had hooked up a few amps in his past & he gunna be there to kindof direct me, hopfully i wont screw up my amp, even though its old, its always good to have an amp right?
Also i was wondern, is it ok if i have 2 amps that push 600WRMS @ 4ohms when bridged & hook them both up to a box with one terminal and has 2 12" subs @ 4 ohms each sub. The subs are rated @ 500 WRMS & 1600 W PEAK so the grand total recomended would be 1000 WRMS, but im puttin 1200 WRMS through them, would that still be ok? one more thing, with both subs hooked up to the same terminal, isnt there a "law" that makes the independence 2 Ohms now, or 8 Ohms, its something like that, yea?KDC-MP5028- Kenwood deck
I would not strap the two amps together like that... can it be done? yeah, probably... can something go horribly horribly wrong? absolutely... much easier to simply put the 600 watts directly on to each sub... pulling a sub from the box and adding a terminal cup shouldn't be tough...It's not good, very fundamentally simply not good. - geolemon
Well, i guess its a good thing that i havent even started the box then right?KDC-MP5028- Kenwood deck
........................But you do approve of the 1200 WRMS to the 1000 WRMS subs? i dont want to screw them up, you know.....KDC-MP5028- Kenwood deck
that would be a plus, yep...Still learning wrote:Well, i guess its a good thing that i havent even started the box then right?
you're using the type-r's, if i'm not mistaken? in that case, the extra 100 watts shouldn't be a problem - be quite sure to set the gains properly, but then don't worry about it...It's not good, very fundamentally simply not good. - geolemon
Actually im using a couple of these 12 inchers....
Do you still think id be ok if i were to use the 100 watts extra?KDC-MP5028- Kenwood deck
probably even more okay... i'm not very familiar with sony subs, but their general target market is the teeny-bopper crowd, so they can probably take quite the beating and keep going...It's not good, very fundamentally simply not good. - geolemon
Ha!!
what exactly is the "teeny-bopper" crowd? KDC-MP5028- Kenwood deck
that's what mac calls them... the kids who buy car audio for the sole purpose of being heard by other people... presumably this is some sort of mating ritual, but unfortunately for us, these people won't die out when their ritual doesn't work...It's not good, very fundamentally simply not good. - geolemon
neomagus00 wrote:that's what mac calls them... the kids who buy car audio for the sole purpose of being heard by other people... presumably this is some sort of mating ritual, but unfortunately for us, these people won't die out when their ritual doesn't work...
yea, well you can be assured that im not one of them, i wan just uneducated and cheap...........KDC-MP5028- Kenwood deck
i think all of us were there at one point... most still are, to a greater or lesser degreeStill learning wrote:yea, well you can be assured that im not one of them, i wan just uneducated and cheap...........
im sure you have herd this question again and again, but what guage wire would you suggest for 600 w/RMS @ 10 feet?KDC-MP5028- Kenwood deck
my friend the cable gauge chart says you can get away with 8 gauge, but 4 gauge is usually the minimum reccommended size... i'd go with 4 - barely costs more, just as easy to run, and better insurance and power flow...It's not good, very fundamentally simply not good. - geolemon
