what kind of amp should i use to power my home made sub??
ward91
I have made a home cinema subwoofer it is quite large about 3.3ft2, i have a 12" sub to go in it that has 400wrms per coil and each coil is 4ohm (dual coil sub) what amplifier for about £80 to £160 ($140 to $280 preferably below $200 ?)
What would you recommend??
ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
Post edited by ward91 on
Have you looked at plate amps on partsexpress.com yet?
ive just had a quick look at postage they use ups to deliver to the uk but i couldnt see a price.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
yes your right but I dont know of any, may maplins cpc or farnell I dont really have a clue , I typed it into Google for uk results only and there wasnt allot of help at all .
just looked cpc dont sell them niether do farnell or maplins others are a bit over expensive.
even if i got a plate amp from the us what would i use to power it .
230v to 110vELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
would it be ok to run the sub of the rear center channel ?
use the 6ch power amp input on the back of my avr, put L/R to L/R and put SL/SR to SL/SR and also put center to center but wire the surround center up to the sub, i know this is impractical as all i could listen to in 5.1 is the pc that is pluged into the 6.1 direct inputs. but would the sound be better or does the sub need more than 80w to get the lower end going? (the subs sencitivity 1w/1m 89dB)ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
Using the rear center channel is not very practical. Can you get an Adcom 545 there? Does the marantz have a subwoofer output that's crossed over?
run the sub out to a y cable to the l&r on the Adcom. Hook one channel to each voice coil (read the subwoofer's documentation to make sure you get the phase correct. That'll get you ~400 watts total (200 to each coil) for about $200 US. You'll have to use the bass management on your AVR (assuming it has it), but the watts per dollar will be hard to beat.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
don't do it. get yourself a sub amp.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
my amp has a crossed over subwoofer output that is low level. and whats a
Adcom 545 is it some kind of power amp?
http://www.marantz.com/new/index.cfm?fuseaction=Products.ProdSpecs&cont=eu&bus=hf&prod_id=2485&type=avr&arch=1ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
???? was that vs the Adcom or vs the rear center channel?BIZILL wrote:don't do it. get yourself a sub amp.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
a sub amp from where ?
i can find almoast nothing in the uk under £200 that is my preferd power so that must be about $350ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
ward91 wrote:my amp has a crossed over subwoofer output that is low level. and whats a
Yes, it's a power amp. Versus a subwoofer plate amp, you'll get more clean wattage, class AB design (instead of digital or class G), very solid specs and a great sound. The drawback is that yuo won't have the nice knobs to twist- you'll have to rely on the bass management in your AVR, which might not work how you want it to and if you need to reverse the phase you'll have to unhook everything.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
does the adcom run of 110v or 230v?
i dont think i will find any in the uk so postage may be high.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
I've seen dual voltage Adcoms in the same line (535, 545, 555), but not all of them are. You'll have to check on that. Regardless, you don't have to go the subwoofer plate amp route... Any power amp will do, so shop around.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
power amps seem to cost new i may get one of ebay i can't seem to find a good plate amp in the uk.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
