Woot.com InFocus 50” Ultra-Thin DLP High Definition TV - 1999.00
Schris22
Schris22 Posts: 983
edited November 2005 in Flea Market
No affiliation as usual just bringing it to your attention if your in the market...
no idea if it's good or not....
Woot.com
* Screen Size 50” diagonal
* Aspect Ratio 16:9 wide screen
* Light System InFocus Engine, worlds thinnest DLP RP
* Microdisplay Type DLP,. HD2+ DarkChip2
* Native Resolution 720p High Definition (1280×720)
* Processes all HDTV modes 1080i, 720p, 480p, 480i
* Screen Type High-Gain, High-Resolution, Fine Pitch
* Anti-Reflective Screen
* Adaptive Video Noise Reduction
* Scan Rate Converter
* 3D Y/C Digital Frame
* 3:2 Pull Down
* Reverse (TruScan Digital Reality.)
* Adjustable Color Temp
* Dynamic Color Stretch Circuitry
* Contrast Expand (B&W Stretch) Yes – Off/Low/High
* Picture Presets Vibrant, Natural, Cinematic, Personal
* Viewing Angle 160 degrees
* Picture Power (watts)150/180 (Lamp Power)
Sound
* Broadcast Stereo w/dbx Noise Reduction
* Second Audio Program (SAP)
* SRS Labs TruSurround XT.1
* 7-Band Graphic Equalizer
* Front Speakers (number) 6 (4 mid-range, 2 tweeter)
* Fully Enclosed Speaker System
* Total Watts 60 (15W/Chan + 30W Subwoofer)
* Integrated Subwoofer Yes – 30 Watts
* Channels/Watts 2 Channels, 15 Watts Per
* Sound Logic Audio Leveler, Sound Presets 7 Modes + Personal
* Dolby Digital Pass-Through
Reception
* Tuning Capability NTSC/ATSC/DCR
* Digital Cable/Satellite Connections DTV-Link. (IEEE 1394)/HDMI./HD Component
* Digital Cable Ready Yes (DCR) and CableCARD. slot.
Convenience
* Auto Channel Search
* Channel Labeling Auto (via EPG data)
* Interactive Set-up w/ Menus
* Integrated Web Browser – WIN CE v4.1 with IE v6.0
* Lighted Control Panel Back-lit Touch Sensor
* Multilingual On-Screen Display English/French/Spanish
* One-Button Launch for Inputs Yes – Auto Tune
* Parental Control (V-Chip)
* Pic Memory Presets for Vid Inputs
* Picture Freeze, Picture-in-Picture Twin Tuner (Analog Only)
* TimersClock/Sleep/Turn-On
Rear Connectors
* RF Input (Antenna/Cable)2 (1 antenna, 1 cable)
* Audio/Video Inputs (Composite)4 L&R Audio, 4 Video
* Component Video Input (YPrPb)2 – SYNCROSCAN. PLUS
* HDMI (High Def Multimedia Interface) 1 for 720p, 1080i, 480p
* Sub Woofer Output Yes – RCA Phono
* A/V Outputs (Composite)1 Set – L&R Audio + Video
* Audio Output (Coaxial/Optical)SP-DIF (Optical)
* IEEE1394 Connector2 w/2-Way DTV Link
* Broadband Connector (Ethernet RJ45) Yes
* Center Chan/Matrix Surround Output Yes – 3 RCA Jacks
Dimensions
* w/o Base 52.60 (W) x 41.46 (H) x 6.85 (D)/ 133.60 cm (W) x 105.31 cm (H) x 17.40 cm (D)
* w/Base 52.60 (W) x 42.72 (H) x 12.80 (D)/ 133.60 cm (W) x 108.51 cm (H) x 32.51 cm (D)
* Weight w/o Base 121.5 lbs/54.7 kg
* Weight w/Base 175.8 lbs/79.1 kg
Receiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
Post edited by Schris22 on
  • aaharvel
    aaharvel Posts: 4,489
    Damn nice.
    anything beats my JVC 36" 4:3 crt. Definitely the weak link in my setup. =(
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • lomic
    lomic Posts: 407
    "Wow, I could buy a big screen TV and it would be awesome!"
    "But hmm, for that kinda cash I could get like... TWO audio upgrades."
    "Ok, I'll just take a LOOK at audigon first."
    "$3000 isn't that much more than $2000! Who needs a TV when your cables are made of silver -- SILVER I TELL YOU!!"
    Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
    Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP)
